Catalytic convertor woes
Old Jan 10, 2024 | 11:45 AM
colorado_junkie's Avatar
colorado_junkie
Good morning everyone
Here's the scoop. About 6-7 months ago the check engine light on my 2011 F150 3.5L Ecoboost started turning on for some time then stay off for some time. It was a random occurrence. I finally got a reading from an auto store and it came out as P0430. The fella told me to use CataClean as a starting point to see if that would fix problem. That worked for awhile but eventually the check engine light came back with the random occurrence again. Just before Christmas I replaced the bank 2 sensor 2 oxygen sensor on the CAT. Check engine light stayed off for about 30 minutes of test driving. The next day when I started up the truck the check engine light turned on and has stayed on since. Now, all evidence points towards a bad catalytic convertor on bank 2 but I was hoping someone has other ideas I can hear to test the CAT before I jump into a replacement. Thanks for the help.
Old Jan 10, 2024 | 06:11 PM
rbentnail's Avatar
rbentnail
Cut it out with a sawzall and file with insurance as crackhead vandalism. Done!
Sorry but that's all I got.
Old Jan 18, 2024 | 06:11 AM
meborder's Avatar
meborder
Check for a temperature rise across the converter.
when working properly, the rear of the converter should be slightly hotter than the front. If there is no temperature rise, or the front is hotter, then it is bad.
This test is done with a non contact IR gun on a fully warmed vehicle.
dropshadow
Dec 18, 2006 05:15 PM
alcooner
Jul 6, 2005 10:49 AM
allcrop
Sep 9, 2002 12:58 PM
eight_up
1983 - 2012 Ranger & B-Series
Apr 11, 2002 09:57 AM
SimpAmz
Dec 30, 2001 10:47 PM
