Alignment with TT Attached?
Old Jan 8, 2024 | 07:51 PM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
Anybody perform a front end/wheel/tire alignment while attached to your travel trailer (TT)? After towing for about hundred miles, I took tire temps from the outside/inside and center of each tire. Rear temps, I guess I’m stuck with, but the front is adjustable.
If you have, please let me know what steps you took.
Thanks.
Old Jan 8, 2024 | 09:59 PM
WE3ZS's Avatar
WE3ZS
With nearly all of my EXs miles logged with the TT on the hitch it’s always had very good front tire wear, so I’ve never worried about it.
Old Jan 9, 2024 | 12:41 PM
Antonm23's Avatar
Antonm23
The front end alignment really shouldn't change when towing.
Excursions (at least the 4x4 models) have a T-type steering setup so toe doesn't change as the suspension cycles, camber is set by the knuckles, so it wouldn't change, and a I suppose if you squatted the rear a bunch castor would change, but it would change in the direction that makes the steering more stable.
Old Jan 9, 2024 | 09:16 PM
ASFC27FTFBQ
Thanks guys. I guess the last guy that did my alignment really screwed up. The heat signatures on each tire (inside/outside/center) was all over the place. This was this past Friday.
Thanks again.
Old Jan 10, 2024 | 08:14 AM
Antonm23's Avatar
Antonm23
I’d be more inclined to look at tire pressure than alignment if the heat was “all over the place “.
Rob89
Nov 23, 2021 06:59 PM
clintbonnie
6.2L V8
Oct 21, 2015 08:25 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 9, 2010 07:14 PM
let_her_flicker
Aug 13, 2007 09:30 PM
jbrdrummer
Jul 14, 2004 07:49 PM
