Computer error codes
Old Nov 23, 2003 | 07:06 PM
mullet's Avatar
mullet
My 87 Ranger (330,000 miles!) recently began running rich at cruise and surging. Disconnecting the vacuum line at the EGR and plugging it helps.
Pulled the codes, it is displaying codes 32 (eps voltage below closed limit) and 34 (eps voltage above closed limit).
Seems odd to have both high and low voltage! Any ideas on how to proceed?
Thanks,
Old Nov 23, 2003 | 07:59 PM
Ken00's Avatar
Ken00
Have you check the fuel pressure and for gas in the fuel pressure regulator vacuum line.
Old Dec 21, 2003 | 09:50 PM
mullet's Avatar
mullet
Thanks for replying. I've been out of town, just checked the link.
I checked the fuel pressure, 40 pounds, and there is no fuel in the vacuum line.
Any idea what the voltage errors could mean?
By the way, I also checked the EGR valve. It just begins to open at 1 pound vacuum. The book says to check it at 5-10 pounds, but doesn't mention when it should start. It is fully open by 5 pounds.
Thanks,
Mullet
Old Dec 21, 2003 | 10:44 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I'm not super familiar with your year of Ranger, but one thing I would be looking at would be functionality of the evaporative emission system. I would also look at the seal on the gas cap and make sure it's sound, assuming that it's a non-vented cap. Also, when you put the gas cap on, make sure it clicks a few times too so it's good and tight.
Old Dec 22, 2003 | 10:44 AM
Ken00's Avatar
Ken00
You'll need to run the pinpoint tests. I can send them to you if you enable your email.
Old Dec 22, 2003 | 07:24 PM
mullet's Avatar
mullet
Thanks, that would be great. But exactly how do I "enable my e-mail". Enable it to do what ???!!!
Thanks,
Mullet
Old Dec 23, 2003 | 09:06 PM
mullet's Avatar
mullet
Ken 00 - Oh, I think I got it. Thanks for the help. philtn@msn.com
