Excursion Gauge Lights
Old Jan 8, 2024 | 01:28 PM
Badaxe's Avatar
Badaxe
Trailering
So recently installed a US Speedo Daytona gauge face. I figured while I had it out I'd do the back lights too and started with a set of red LEDs. After getting it back in the only lights I had were the blinkers and right side gauges. Put some regular bulbs back in with the same results. Interestingly, had a speedo light work momentarily on the way to work Saturday.
So now my challenge, what I need help with, is going to be powering the gauge lights while they're out of the truck. Which plug(s) and which wires are my back light's power and ground? Any tips and guidance appreciated.
Old Jan 8, 2024 | 04:06 PM
Franklin2's Avatar
Franklin2
What year? Diesel?
Old Jan 8, 2024 | 04:46 PM
Badaxe's Avatar
Badaxe
Trailering
Sorry I thought all that had been updated to show up. 2005 Excursion 4x4 6.0L. Interestingly it's a 2004 dash match.
Old Jan 8, 2024 | 05:08 PM
Badaxe's Avatar
Badaxe
Trailering
US Speedo Daytona in "gold" matches tan interior.
Old Jan 8, 2024 | 06:01 PM
Franklin2's Avatar
Franklin2
When you pull the cluster, look at the large plug or plugs, there will be a lightblue/red wire in one of the slots. That is the illumination wire. Count over how many slots, that should be it. You should be able to follow it on the circuit traces, and it should hit just about every bulb on the circuit board for illumination.
Old Jan 8, 2024 | 06:13 PM
Badaxe's Avatar
Badaxe
Trailering
Cool. Thank you Sir. I've got to wait for the subfreezing weather to end, but will update when I get there.
bubba_3711
Mar 8, 2012 06:39 PM
fordguy712
Nov 5, 2008 07:49 AM
powerstroke1869
27
Jan 29, 2008 08:21 PM
Stoner150
1997 - 2003 F150
Jan 10, 2004 11:32 PM
