Sponsored by: Kumho
Key won't turn
Old Jan 7, 2024 | 03:40 PM
Froggiesford's Avatar
Froggiesford
1st Gear
Key won't turn
03 ford expedition
So the steering wheel is not locked but the key still doesn't turn.
my problem is that I can't remove the lock cylinder with the key in the off position.
Any suggestions would be much appreciated. Thank you 😊
Last edited by Froggiesford; Jan 7, 2024 at 03:42 PM. Reason: Forget to mention type and year of vehicle
Old Jan 8, 2024 | 05:36 AM
JWA's Avatar
JWA
Lower the entire steering column looking for issues with the operating components typically not visible when its installed in its normal place. Perhaps you could also temporarily remove the sliding ignition switch (2 Torx fasteners) to see if something inside has broken.
I'm assuming the '03 Expedition is similar to that same year E and or F Series columns.
Baby John
Dec 30, 2023 09:49 PM
nopeda
Aerostar
Aug 2, 2016 09:49 AM
onestep651
1997 - 2003 F150
Mar 2, 2007 12:24 AM
johnclements
1983 - 2012 Ranger & B-Series
Dec 2, 2003 09:38 PM
kymberlyee67
Apr 21, 2003 09:52 AM
