do ya? i was curious since theyre only 1.5" lift. So i could swap to those springs and keep my carli track bar??? I wouldnt mind going down in height...assuming my 37's on 0mm wheels fit still
There have been posts from at least one owner of the 20-22 gen who installed a 1.5" lift and said it required no track bar adjustment. The axle was centered with the stock unit. Not sure if the same would be true on the 23+. The Carli track bar might not have enough adjustment to work with a 1.5" lift, not sure if it can adjust short enough. Maybe.
I did some looking and I cannot find a 3-inch rear block. The closest appears to be 4 in
The OEM 17-19 block is an option. It's the same block used at the rear of the 20+ with Tremor pkg and measures approx. 3.25" at its tallest point. PMF also makes rear blocks in several different sizes https://www.pmfsuspension.com/2017-2...cks_p_173.html.
Frankly I understand why these trucks come looking ridiculous anyway. Why not make them as level as possible and if loaded keep them from sagging so bad. I loved my 08 with the snow prep package. Was able to run a properly sized tire with no level kit. Why not toughen the back end instead of neutering the front suspension to make it level when towing? There should be a toe heavy package and a weekend warrior/daily driver package? I shouldn’t have to pay for tremor or snow plow prep to have a leveled truck.
I don’t mind the stuff ride of a super duty. It’s a big truck not a Cadillac
I think the reason is that you might be the minority as far as Ford is concerned. Not many owners want a stiffer riding truck for the sake of a look, a look that isn't appealing or wanted by all. The same size tires can fit with base coils that can with plow prep or a level. You must not have looked closely enough at a Tremor pkg truck, they have a good amount of rake too. The coils give a small lift and to compensate for that they include a taller rear block. Even the plow springs (plow prep) doesn't give a true level if that's what you want. They give tops 1" over base springs. Most of these trucks come in at 2-2.5" of rake. Even more in the 17-19 trucks.
What's wrong with buyers having to pay more for a level look?
Im not in the minority at all. Do a search on level kits and how to do it. While a lot of super duty owners tow some don't often. There are far fewer requests if how do I level my truck while loaded. Some rear drop should be expected while adding weight to the rear of the truck. But while a truck in its natural stance should sit more than 2-1/2” off of level.
ironically enough the title of this thread wasn’t how do I make my truck level while towing. It was how do I make my truck look natural while in its natural state. So it would make more sense to me that there would be a package for this of use that wants a normal look while unloaded. That’s all.
We must be looking at different threads because the title of this thread is nothing like you say haha. Also, earlier I said as far as Ford is concerned you may be the minority. I am not Ford. Since when is level a "normal look" for an unloaded truck?
I do not use my truck for towing but also don't care for a level stance. My '19 has 3" of rake and I still think it's a great looking truck. Could it be less, sure, but it doesn't bother me. Not sure if you remember the previous gen, when the 350 sat higher in the rear than the 250. The level look of that gen 250 looked off to me, I did not like it. Don't mistake that for meaning I don't think you or anyone else shouldn't want to level their trucks, by all means do what you like, I just don't see why a manufacturer should cater to that. Especially considering it's so cheap and easy for the end user to add a level kit if they want.
I understand all of that. And yes I do remember the 350’s switch more rake. Perhaps you came from the hot rod generation where there was rake in hot rod street cars IDK lol. But to me it doesn’t look right. And apparently due to all the threads and the aftermarket for leveling kits I’m not at all in the minority on that regard. Maybe ford does it for a different reason but that also doesn’t make it right. But when I spend 80k on a truck I shouldn’t have to go modding it for it to look level. The tremor package or snow plow prep are options but I didn’t order my truck. My 08 had the snow plow prep. Didn’t have to touch it. Ran 35” tires and no issues. These trucks come with the grandpa package and it sucks is all I’m saying. I want something different and it should be an option in this type of price range.
what? the natural state of my truck is hooked to a trailer. idk what you're talking about.
what you're asking for is the best of both worlds, a level soft riding truck that doesn't sag when loaded. lol. airbags kind of do that but they have limits as well with ride quality. Mine rides nice with and without the trailer. it definitely sags with my trailer though....pretty badly depending on how the tongue weight is loaded
