Sponsored by: Real Truck
Fuel Gauge Adjustment
Old Jan 16, 2024 | 09:19 AM
madsonp's Avatar
madsonp
Originally Posted by Racer Z
Yesterday, I finally ran out of gas, 430 miles from last fill-up. Dumped in five gallons that I had with me and motored two miles to the gas station and filled up. In total, 38 gallons.
I had some SeaFoam with me, enough for 44 gallons, so I dumped that in during fuel fill. I had read the info on all the SeaFoam type products at the parts store. Most didn't say much at all. SeaFoam had the most info, but they all seemed about the same. The most consistent was to use one once per one gallon. You can use more if you think the 'gum' build-up is sever.
Today I disconnected the battery for 30 minutes, or more.
Now it's a matter of time before I can see any results.
It might take a couple of treatments before you see any results, next time if it doesn’t fix it on this tank of gas, try the Techron additive and see what that does,
Old Jan 16, 2024 | 10:05 AM
Don Ridley's Avatar
Don Ridley
Sorry, I have to say this: gasoline is a strong solvent. If you wanted to clean almost any type of gunk, and weren't afraid of catching on fire, you could use gasoline. Adding another solvent into your gas, in very low concentration (one bottle in 35 gallons), is unlikely to do anything. It's like adding a shot of simple green to a bottle of Dawn dish soap. You just have more soap.
Old Jan 16, 2024 | 08:20 PM
Pickupmanx2's Avatar
Pickupmanx2
I'll lay my 20 bucks on the battery disconnect doin the trick, had that work a few times for me...
Old Jan 17, 2024 | 03:53 PM
Racer Z's Avatar
Racer Z
4wd Low
Well, after I filled the tank, the digital read-out said, "410 miles until empty". After the battery disconnect it says, "560 miles until empty". Considering that I just got 430 miles on a full tank, the 410 estimate was acceptable. Hopefully it will sort itself out soon.
Yes, I have used gasoline as a solvent, works great. Old gas turns gummy and fresh gas usually doesn't remove the gum and turpentine or shellac like residue. I've worked on enough old cars in my time... been there done that... That's why SeaFoam or some other snake oil is necessary. I did not use one small can, I used two large cans. One once per gallon, I used enough for 44 gallons in a 38 gallon tank.
It's still a waiting game to see what the long term results be.
Old Feb 14, 2024 | 12:57 PM
Racer Z's Avatar
Racer Z
4wd Low
The results are in!
I've burned up some gas and watched the needle and trip-meter.
  • At 100 miles the needle was on the 3/4 mark.
  • At 200 miles the needle was on the 1/2 mark.
  • At 300 miles the needle was on the 1/4 mark.
  • At 300 miles the digital readout thinks I've got fuel for another 200 miles.
The needle seems consistent with my previous findings of 430 mile on a full tank. The digital readout is off by 100 miles or so. I can work off the trip-meter and needle while ignoring the digital readout. I'd prefer the needle to be accurate (within reason), which it seems to be now.
Which was more effective, the snake oil or the battery disconnect?
I didn't want to spend the time doing a scientific experiment, so I did both at the same time. My best guess is that the battery disconnect (with tank full) was more effective than the snake oil.
Thanks for your advice everybody.
Old Feb 19, 2024 | 10:55 AM
Pickupmanx2
Glad ya got it working somewhat and thanks for letting us know!
kountzecobra
May 16, 2022 07:10 AM
jrwendell
6.7L Power Stroke Diesel
Jun 14, 2011 07:01 AM
wrdabney
Dec 8, 2009 11:23 PM
hangon2me
Mar 1, 2009 07:40 AM
