ignition/starting problem
Old Nov 23, 2003 | 06:06 PM
slntnddly's Avatar
slntnddly
Angry ignition/starting problem
I need to know why my truck wont stay running. When i start the truck, it will stay running as long as i hold the switch in the start position, but when i let it go back to on, the truck stops. Could the timing affect this? (i know the timing is off, but i dont think its that bad) I have a new switch, lock cylinder, battery, and starter in it.
75 f100
302/spd auto
Old Nov 23, 2003 | 06:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Bad wiring to the coil or ignition module in run mode.
Check for power at the coil and at the ignition module with the key ON.
Old Nov 24, 2003 | 07:03 PM
slntnddly's Avatar
slntnddly
i know there is power at the coil because when i got the truck, i could put the key in the on position and jump the truck off the starter solenoid (long story why i had to do it this way), but where do i check for the ignition module power? in addition to this problem, when the truck is turning over/starting the carburator blows flames out. i had a friend tell me that it it a backfire through the carb due to the timing being off. is this accurate or is there another problem?
Old Nov 24, 2003 | 07:08 PM
slntnddly's Avatar
slntnddly
starting problems
I need to know why my truck wont stay running. When i start the truck, it will stay running as long as i hold the switch in the start position, but when i let it go back to on, the truck stops. Could the timing affect this? (i know the timing is off, but i dont think its that bad) I have a new switch, lock cylinder, battery, and starter in it. in addition to this problem, when the truck is turning over/starting in the start position, the carburator blows flames out. i had a friend tell me that it it a backfire through the carb due to the timing being off. is this accurate or is there another problem?
Old Nov 24, 2003 | 07:14 PM
Franklin2's Avatar
Franklin2
The backfiring when the engine is cold is normal, especially if your choke is not working.
I agree with Torque1st, you need to check for power at the + side of the coil with the key in "run". There is the possibility the resistor is burnt out, but check for power first.
Old Nov 24, 2003 | 07:19 PM
drunkenmonk's Avatar
drunkenmonk
sounds like the coil isn't getting juice in the run position
does your solenoid have four terminals or three?
Old Nov 24, 2003 | 07:53 PM
slntnddly's Avatar
slntnddly
there are four terminals that are all properly connected
Old Nov 29, 2003 | 05:24 PM
slntnddly's Avatar
slntnddly
i decided to start with the ignition switch to check for power. i have 6 prongs on it, one of which is a dummy prong. four of them have power when they are supposed to, but the purple/white wire that goes to the dual brake warning switch (according to the haynes manual) has no power. i tried the switch in every position and still got nothing on it. where is this brake switch and what exactly does it do? could this have something to do with my truck not running with the switch in the on position?
Old Jan 12, 2004 | 02:24 PM
JoeBlow's Avatar
JoeBlow
I know this is an old thread but I am curious to see if he got it running? I am getting the same problem on my F100 right now. This may sound stupid but how exactly do I check for power. I am such a moron when it comes to electricity.
Thanks guys
