Help Me Please Urgent
Old Nov 23, 2003 | 05:35 PM
homoudont's Avatar
homoudont
Angry Help Me Please Urgent
ok i hooked up a new exaust manifold last week. now every tiem we drive it during the eccelartation time from 0 to 15 it makes a terrible shutterign noise. it is nto the engnine. nor do i think it is the tranyn what else coulld it be. could it possible be the exaust smakign against the tranny mounting member? the cross memebr on the frame. i do have an exaust leak on the pipe that comes from the rigth side of the manifold to before the cats it suposed to be conencted its not rigth now cause i ahev to tape it up their. im goign to use some of that metal chimney tape?? is that a good idea.
what could be causing that popping noise??
please help
thank you so much
Old Nov 23, 2003 | 06:15 PM
mcanik's Avatar
mcanik
Sounds like it could be a heat shield covering the catalytic converter(s) a little loose and vibrating. Possibly one of the spot welds broke.
Old Nov 23, 2003 | 06:38 PM
homoudont's Avatar
homoudont
i dotn think thast the issue hope its that simple, i think it migth be the tranny or just the muffler came off the braket again and is shutering! i hope i can figue this out soon. im just sick of workign on it and nothing going right.
Old Nov 23, 2003 | 07:25 PM
steve83's Avatar
steve83
No, tape is NOT a good idea. It'll tear. Attach it right and you'll probably fix everything. If you can't do it, take it to an exhaust shop or a dealer.
Old Nov 23, 2003 | 07:59 PM
homoudont's Avatar
homoudont
its really loud liek shuttering really bad and sheakes the hoel truck basically sounds bad inside but not too bad outside
Old Nov 23, 2003 | 11:19 PM
BANTHEBOWTIE's Avatar
BANTHEBOWTIE
Did you get new gaskets and install them? If not I suggest you buy some. Whenever you replace a manif. you need to get new gaskets for it to seal properley.
Old Nov 24, 2003 | 06:34 AM
homoudont's Avatar
homoudont
yes i did, got the felpro gaskets. some peole on here told me nt to put them in becasue they willl crack and leek. maybe thast tru but its like 1-3 years down the road. unlike leaving it with no gasket and gaving it leak all the time. my father said their was no metal noise it was all exaust. i dont agreee wiht him their was somekind of knockign going on. but only form 0-15 ??
could the tranny be low on trans fluid? ill have to check it wehn i get home from school as well as im gunn crawl under( in the snow) and see what the #&^% is making that noise.
it didnt seem to have any problem pullin ghte 500LBS of lumber in the bed.
see i cant drive yet so this is what my dad has told me. it seem harder to accelerate? would that have to do with the pipe that goes in before the cats being broken off?
i think it might effect the O2 sensor.
when not actually moving the engin revs compleatly normal. and i had no problems with it speedign up when was backing down my drivway and floring it forward and sloshing through the mud. i had never hered that noise before.
so im goign to check all the exaust, and check the tranny fluid!
that seem liek a good place to start?
the actual noise is commign from under the passenger side cab
thank you for you help
Old Nov 24, 2003 | 03:25 PM
BANTHEBOWTIE
It might be your tranny, but I woulddn't think so, The only other thing I can think of is if along with the noise you feel a shuuder then it could likely be the tranny or you might be low on diff. fluid.
Old Nov 24, 2003 | 04:47 PM
homoudont's Avatar
homoudont
i was just cheakign out the wheel well u know the plastic cover for the wheel and i think not sure what was happenenig id the cover was gettig sucked down by the tired and rubbing?? could that eb the noise? i think so
Old Nov 24, 2003 | 06:50 PM
homoudont's Avatar
homoudont
**** fugured it out!!! the 2nd cat was smashing agains the support member for the tranny. i wwedged a piece of metal inbetween and it stopped. the reaosn i was from 0-15 was that the engine as sheakign from 0-15 then once it hit the speed it stopped sheaking.
thanks
it was the easiest **** to figure out.
