Help needed identifying the correct master cylinder
Old Jan 2, 2024 | 04:01 PM
jared5150's Avatar
jared5150
4th Gear
Hi All,
Got my 78 F-250 Supercab six months ago and the breaks were going all the way to the floor and I think I have it narrowed down as being the master cylinder. I bought a new master cylinder, bench bled it, went to put it on and the brake lines were on the opposite side from the old master cylinder. The old master cylinder had the brake lines coming into the right side of the master cylinder, when the master cylinder was installed on the truck. I could move the brake lines, but wanted some more opinions before I do that.
I guess it is possible the wrong master cylinder was installed on the truck when I bought it, or multiple master cylinders will work on the truck. The other item of note is that it has disc in the front with two pistons.
The MC part listed on LMC has the brake lines on the left(different from my old MC) - picture attached. Part 45-4025.
The MC from Oreilly's is here, but it was the two piston version. BrakeBest Select Brake Master Cylinder - New NMC11370 | O'Reilly Auto (oreillyauto.com)
Question, are the two parts I sourced wrong and I need to find an MC with the ports on the right side(like the old MC), or do I use one of these new ones and move the brake lines?
Thank you,
Jared
Old Jan 2, 2024 | 04:19 PM
redroad's Avatar
redroad
You could rebuild the old one. You might have to hone the bore or have someone else hone it for you depending on what the bore looks like. Usually a kit will get you going for a good while.
Old Jan 3, 2024 | 01:08 AM
DB429SCJ's Avatar
DB429SCJ
Looking at parts catalogs,it depends on what calipers you have. Single piston- ports are on the right. Dual piston-ports are on the left. That 45-4025 would fit trucks with dual pistons.Yours must have been replaced with the wrong part. IMO ,install the correct part and move the lines.
Old Jan 3, 2024 | 09:07 AM
tbear853's Avatar
tbear853
You might need to change a fitting or adapt.
I don't have a F-250, I have a F-150 with single piston calipers, it had an 11" single diaphragm booster, and the lines went to the right side of the master cylinder. I chose to upgrade brakes.
I made changes years ago, mounted a F-350 9" dual diaphragm booster with F-350 master cylinder, the lines then were moved to come into the master cylinder on the left. I also put larger pistoned T-bird calipers in place.
Old Jan 4, 2024 | 09:50 PM
jared5150's Avatar
jared5150
4th Gear
Thank you, all. I will go with the MC with the ports on the left side as I think that is the correct part. I will then have to move the brake lines to the other side. Thank you for your help!
Old Jan 5, 2024 | 04:13 PM
Then399!'s Avatar
Then399!
Sorry I've been away for a bit. My 1976 F250 SC trailer special has the original master. The lines on mine are on the left side. It has a bore of 1.25 inches. After ordering three different masters all different I did a rebuild on it. First one had the lines on the right, the second one had a 1 inch bore and the third gave me a push rod adjustment issue. Brakes are working like they did in 1976...
dcarnut1
Sep 2, 2008 03:56 PM
fordinmudd
Apr 12, 2006 03:33 PM
WillyB
Sep 15, 2005 08:27 PM
fatfenders
Sep 14, 2002 10:08 PM
