BRN/WHT
Old Dec 31, 2023 | 08:41 PM
TheGreatPumpkin's Avatar
TheGreatPumpkin
BRN/WHT
Howdy Ya'll,
I can't seem to find this BRN/WHT wire on the diagrams. It shared the same green plug that services my BRN wire for all the turn signals located near duraspark module. It goes in the cab, past the cluster and towards the passenger, doesn't seem to pop out on the other side of the engine bay with the other wires.
I replaced the turn signal wires (Brown wires) that service both front front lamps and the rear lamp. Not sure where off the top of my head this would be going too.
Could use the help before I tear apart the glove box trying to trace this down.
Old Dec 31, 2023 | 08:43 PM
TheGreatPumpkin
On Left
Can we not upload PDFs on this site?
Old Dec 31, 2023 | 09:19 PM
redroad's Avatar
redroad
I like "Electra clean" made by "CRC' to clean those electrical contacts and plugs that are really nasty inside like the ones above.
https://www.crcindustries.com/lectra...aser-19-wt-oz/
Old Dec 31, 2023 | 09:23 PM
TheGreatPumpkin
I always have a can of that at hand but oh no friend these plugs are being removed, they are disintegrating.
Old Jan 1, 2024 | 03:11 PM
broktruk's Avatar
broktruk
Originally Posted by TheGreatPumpkin
Howdy Ya'll,
brn/wht should be the power wire for the fuel tank selector valve. It applies power from the selector switch when on the front tank. Find your valve and clean the wire, you’ll see the other end there
Old Jan 1, 2024 | 09:27 PM
TheGreatPumpkin
Thanks I've seen that under the truck its caked in 4 decades of mud but I could barely make it out. Will take a closer look when I can.
Old Jan 1, 2024 | 09:58 PM
TheGreatPumpkin
Is it supposed to share power off the lighting circuit? I'm guess I'm wondering why it shared the same plug as the lighting circuit. I mean it may have been a convivence thing maybe to have the disconnect in one plug for both circuits and not share power.
Just speculating what those Detroit electrical Wizards were smoking.
hotkarl13
Feb 18, 2023 06:01 PM
Ultrapilot
Feb 22, 2022 04:23 PM
Ikari221
6.7L Power Stroke Diesel
Dec 31, 2021 07:57 AM
EMT
Nov 4, 2018 08:31 PM
ChiefGeek
Apr 18, 2018 05:40 PM
