Cp4 pump replacement only
Old Dec 28, 2023 | 05:12 PM
Yankovision's Avatar
Yankovision
2nd Gear
Hey guys so I have a 2011 f350 233xxx miles. Sadly I didn’t know what I was looking at when I purchased recently and was lied to about the true condition of the motor. Anyway. It needs a fuel system. I’ve researched to the ends of the internet and am wondering if I could purchase a remanufactured cp4 pump just to get the thing going again. I know you are supposed to do the lines and rails and injectors and all that but I don’t have $10k to put in it right now. So can someone please tell me their thoughts on this.
I drove it home 120 miles after purchase and then it went to crap. It will start with a sprits of either (don’t shoot me I know it’s not recommended on diesels) but it will run. The only issue that I’m having now is that once it tries to shift into second gear it will blow the return fuel line off one of the Ts. You can pull over and push it back on and get going again but have to keep it in first gear. I just purchased a new return line but haven’t put it on yet.
Old Dec 28, 2023 | 06:07 PM
Just Chilling's Avatar
Just Chilling
No, I did and still spent the 10k. Mine hadn’t even trashed itself, it still run fine just didn’t have enough flow during a regen and pulling trailer it would drop pressure and set a code then derate.
We changed the pump and I run it 3 months as injectors seemed good but they weren’t and I got to buy injectors and fuel rails anyway.
In sellers defense he may have been totally inoccent , those things generally do not give any warning so I would not be to hard on him unless you have ample evidence. Good luck.
Old Dec 28, 2023 | 07:33 PM
Yankovision
2nd Gear
So 3 months later you had to spend more money but did have to replace the pump again?
Old Dec 28, 2023 | 08:04 PM
Overkill2's Avatar
Overkill2
I do not believe that you can buy a remanufactured CP4... if you know you have a fried CP4, by removing the MPROP or FCA from the top of the pump and saw debris on the screen, you will need a whole system like Just Chilling said because the injectors will be shot and everything else contaminated with metal debris, including the return line back to the tank and in the tank.
Old Dec 28, 2023 | 08:44 PM
Just Chilling
That part of the story is still being written, we did not but it’s still not running right. I actually limped it home last night and am driving a …………Ram😲😲…….. right now. I think it may get replaced again. It never idled smooth, the fuel rail pressure is always hunting. Sometimes drops and truck shuts off.
Old Dec 29, 2023 | 07:36 AM
Overkill2's Avatar
Overkill2
I feel for you since I own a 6.7 Powerstroke as well... Good luck to you...
Old Dec 29, 2023 | 07:47 AM
scraprat's Avatar
scraprat
Top Answer: 5
Feel for you also.
It seems with these diesel beast there is no half fix if the cp4 goes without prevention kit on it.
Old Dec 29, 2023 | 09:41 AM
scraprat's Avatar
scraprat
Top Answer: 5
OP in this video of adding a prevention kit go to minute 25 for a couple of minutes when they show the screen. If metal is present.....
Old Dec 29, 2023 | 11:15 AM
Overkill2's Avatar
Overkill2
Originally Posted by scraprat
Feel for you also.
It seems with these diesel beasts there is no half fix if the cp4 goes without prevention kit on it.
x2 OP... if you are going to move forward and plan on driving the truck for many miles after investing this kind of money, think about installing the Gen 2 kit to protect your investment.
Old Dec 30, 2023 | 06:50 AM
eddienelson's Avatar
eddienelson
My warranty expires in 1k miles. I’m having nightmares about this. I’m looking into the dpk but I’m not 100% convinced. I’ll watch the video posted today.
Old Dec 30, 2023 | 07:35 AM
scraprat's Avatar
scraprat
Top Answer: 5
You could always go this route and be done. Maybe even sleep well with no nightmares.
Old Dec 30, 2023 | 10:08 AM
Overkill2's Avatar
Overkill2
The video posted is just an install video...
Here's the videos where S&S intentionally damage the CP4 and continue driving it to see how well their kit protects the system and how far the truck will go on a damaged CP4. They did it to 2021, but I'll post the series of videos that deals with our gen trucks, the 2011 to 2016.
Old Dec 30, 2023 | 10:25 AM
Overkill2's Avatar
Overkill2
https://youtu.be/KoRZTgGOdBw?si=QW5mwdQjFrbJ_aGH
Old Dec 30, 2023 | 10:51 AM
scraprat's Avatar
scraprat
Top Answer: 5
When I watched the SEMA video of the DCR they mentioned that the prevention kit wasn't needed but if installed wouldn't hurt anything. The DCR won't eat the whole fuel system if an issue arises.
Really has me thinking about it but I don't want to do it myself. Doing it in the open air of the desert at one of my boondocking location isn't a good senerio if something breaks. Civilization can be 30+ miles away.
2016 truck only has 63k miles and I keep them forever and being in the west not seeing snow, not being near the coasts getting salty air the under carriage is like new conditions. Like Overkill2 I'm originally from western NY and don't not miss my trucks rusting away between year 4-8.
Edit...did you mean this video @Overkill2 ?
Old Dec 30, 2023 | 11:12 AM
Overkill2's Avatar
Overkill2
Watch the video I just posted... they just eat up it up and keep going... but now that I have one, A Gen 2 DPK, maybe I'd keep it on if or when my CP4 went (just more filtration is all)... because I would swap in a DCR pump no doubt.
Too bad you weren't closer Rat, I'd give a fellow WNYer a hand... you talking the DPK or the DCR, to install?
My truck is 7 years old and is not a rust bucket. I get it oiled every year. I'm going to do a thread at one point with the pics I've taken on how I've dealt with the rust, what I've done and what I still have to or rather want to (MonstaLiner on the body along the lines for example)...
