2018 Battery Insulation
Old Dec 26, 2023 | 02:23 PM
Shernius's Avatar
Shernius
First off are they necessary since they don't completely surround the battery on all sides?
Second, I picked up an H7 battery and the truck turned out to have a H6. The insulation that was on the H6 does not fit the H7. Is there a different insulation that larger and fits the H7 battery?
Old Dec 26, 2023 | 03:15 PM
JKBrad's Avatar
JKBrad
It's not really needed. Yes, there is a larger insulation part available. There are f150s that come with an H7 from the factory. Or you can just make a piece yourself with some insulation you buy on a roll at Home Depot, and some duct tape.
Old Dec 26, 2023 | 03:44 PM
Shernius's Avatar
Shernius
I was actually looking at the Design Engineering 010480 kit, but since I need to go to HD or Lowes I'll take a look at what they have.
Old Dec 26, 2023 | 04:45 PM
JKBrad's Avatar
JKBrad
Yeah, I think I have part of a roll of silver poly insulation that cost 10-15 bucks. That and some good quality duct tape will save you a lot of money.
Old Dec 26, 2023 | 05:34 PM
GlueGuy's Avatar
GlueGuy
When I replaced the OEM battery with a little larger after-market battery, I had to cut the insulation blanket to get it to wrap around. It was about 1-1/2" short. So after I cut and measured, I got out a roll of pipe-wrap tape, and made a "bridge" of sorts to fill the gap. I put the taped part on the outside of the battery (away from the engine. It's been that way for over a year now, and seems to work just fine. Since the black tape is almost the same color as the insulation blanket, it looks perfectly normal (as if that makes a difference anyway). It might be 25 cents worth of tape, plus $150 of my labor of course.
Old Nov 29, 2024 | 06:45 PM
stvneil's Avatar
stvneil
Battery
Interstate H6 AGM works fine
Old Nov 29, 2024 | 07:36 PM
Shernius's Avatar
Shernius
your a little late to the party cause I delt with this almost a year ago
1986F-150
2019 - 2023 Ranger
Sep 2, 2023 07:16 PM
Rockinfigs
All Things Towing
Jul 27, 2023 10:55 AM
arfayq644
2019 - 2023 Ranger
Mar 22, 2023 07:28 AM
BBsound
2021+ F150
Oct 27, 2021 05:32 PM
