92 5.8 Low compression
Old Dec 26, 2023 | 05:39 AM
Eff1Fiddy's Avatar
Eff1Fiddy
1st Gear
Hello all. Just wanting to get an opinion or 3. I have a 92 with a 351 w/ 219k miles, all stock. About a year ago, just started running crappy outta nowhere. Misfiring condition combined with shuddering shifts, especially 3-4. Haven't driven it much at all since. Finally about a month ago, I decide to look deeper. Did a compression test. I'm 120-130 across the board.... except #1. It's at 30psi. So then, i put just a drop of oil onto the top of the cylinder and retested the compression...still at 30-32 psi. If I'm correct, if the pressure would have went way up, that would mean the rings would be shot? So am I looking at the valves now?
How easy is it to pull the heads off of these things? I've never worked on one before. I'm no mechanic by far, but not afraid to turn a wrench, as I've owned and worked on several Turbo Coupe Birds & done a lifter job on an LS motor.
And i guess the secondary question behind all of this is, since it looks like I'll be taking the head(s) off, what would be things to do or any good supporting mods to do while in there?
Old Dec 26, 2023 | 08:13 AM
Mudsport96's Avatar
Mudsport96
Well cylinder one is a concern definitely. But 120 psi is not the worst i have seen, are you doing this hot or cold engine? Are you doing the compression check with the throttle wide open?
If I were you. I would knock the guts out of a sparkplug and weld a air chuck to it and do a leak down check. To see if the air is going passed the rings or out a valve.
Or buy a leak down tester from harbor freight or amazon, they are relatively cheap.
This does a couple things.
1. Tells you right off if it is a ring or valve problem
2. Keeps you from doing extra work ( pulling a head in the truck, if the whole engine needs to come out)
If it is just a valve problem, you may get by throwing a used head on it and get back on the road.
Old Dec 26, 2023 | 11:03 AM
TobyB's Avatar
TobyB
Drive it a bit and recheck compression on #1.
It's not uncommon for something stuck to a valve seat-
often, carbon chunks from pulling a plug-
and that'll mess with the numbers.
#30 is too high for valve damage- once a valve loses seal, combustion pretty quickly burns it to the
point where it won't build pressure at all.
t
Old Dec 27, 2023 | 09:25 AM
manicmechanic007's Avatar
manicmechanic007
Pull the valve cover
Inspect the valves and their movement for cylinder 1 compared to the rest while cranking over or running if you put it back together
Make sure one of the valve springs is not broken or the pushrod bent
Shoot shop air into the #1 spark plug and check for the valves leaking with number 1 in firing position TDC
See if the shop air injected into cylinder 1 comes out the other valve cover breather (indicating a piston or bore issue)
If it shoots a bunch of air out the intake or exhaust, then pull the heads off and inspect the valves
Chisum5013
Feb 4, 2016 01:14 AM
rjb2z
Oct 31, 2007 05:42 AM
jpjahn
Jun 2, 2006 09:46 AM
fordberg
Dec 13, 2005 12:51 PM
christaylor
Aug 10, 2004 07:21 AM
