Need Help Please!!!!
Old Dec 27, 2023 | 03:39 PM
56exp's Avatar
56exp
The instruction sheet from mid fifty that came with mine a year ago said to check the float as they had some that wouldn't float in gasoline !!! Dean
Old Dec 27, 2023 | 05:51 PM
abe's Avatar
abe
Yes. The floats are not hollow brass. The are, I think, solid neoprene.
Old Dec 28, 2023 | 02:25 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Like stated by the OP it works outside the tank but not when mounted. So my first though would be that when it gets screwed down, and grounds to the tank, it prevents it from working. Part of my diagnosing would be to install it in the tank without screwing it down and see if it works then. If it works then I would consider using plastic screws and isolating from grounding on the tank. It can't hurt in trying to isolate the problem. All this might be all for naught it he has a sunken float.
motogotor
Sep 17, 2021 04:20 PM
BTclassics
30
Aug 14, 2017 10:35 PM
elkarcher1716
Nov 24, 2015 09:38 PM
carbs & chrome
May 16, 2015 09:16 AM
forager
Jul 29, 2014 11:05 AM
