New issue today
Old Dec 24, 2023 | 05:45 PM
KU4OJ's Avatar
KU4OJ
I set the parking brake, which may or may not be an e-brake for all I know, only in 3 situations:
1. Parking on a slope.
2. Parking with 5th wheel attached.
3. Parking in a bad neighborhood. With the Ravelco now installed, makes it harder to drag away.
Old Dec 24, 2023 | 06:20 PM
Bugzilla46310's Avatar
Bugzilla46310
I set the parking brake every time I park. Mine makes an audible noise you can hear if the driver window is open. Service manager says it’s normal. Had him document it anyway.
Old Dec 24, 2023 | 07:50 PM
twobelugas's Avatar
twobelugas
the 23 and up have the electronic parking brake modules so they are activated with a motor and some noise is probably normal when the mechanism clamps.
Old Dec 24, 2023 | 07:59 PM
FishOnOne's Avatar
FishOnOne
The F150 have this same setup and make this foreign noise if your not used to it. BTW the only time I use my parking brake is when I'm using the boat ramp so it get's somewhat frequent and never had a problem with the mechanical brake function.
Old Dec 25, 2023 | 02:46 AM
Vipersgts1's Avatar
Vipersgts1
I think it sounds like the alarm on the death star. I like it.
Old Dec 25, 2023 | 08:00 AM
wizardfitz's Avatar
wizardfitz
Originally Posted by twobelugas
I always use mine because I often parking on slight inclines that otherwise cause the truck to come to rest against the parking pawl, the transmission makes a ruckus when I take take out of park the next time I move. this is more exacerbated when I have a trailer hooked up.
Thats why I use mine, didn't know the technical term just remember my dad telling me when I learned to drive in the 70s it was bad fir the tranny not to use it
Old Dec 25, 2023 | 08:01 AM
wizardfitz's Avatar
wizardfitz
Yes, me and my wife both can hear the motor were ing (sp?)
Old Dec 25, 2023 | 08:17 AM
GetMore's Avatar
GetMore
I have never tried applying an electric parking brake while in motion, but I have always wondered what would happen. Part of the question has also been whether it would immediately release or stay locked. I have never had the perfect combination of conditions to test it. (Low traction, open area, wife not with me . . . )
I suspect the systems are set up to prevent use while driving, for safety reasons. This makes them parking brakes, not emergency brakes.
The system Ford uses is an electric motor actuating the rear calipers. They do not default to any position if they fail, they merely do not change position. IOW, they don't fail applied or fail released, they just stay as they are.
I have never heard of any electric parking break applying with the vehicle in motion, so claiming to be worried about them applying at 70 is not likely to get you anywhere. But you're welcome to try it.
Old Dec 25, 2023 | 08:24 AM
Rwhjr's Avatar
Rwhjr
some people like to fear monger.
but yeah for it to happen there would have to be a few simultaneous failures that align to allow the parking brake to come on while driving at speed. Aka take your pick of something else that is more likely to fail to cause you danger than this
you have more reason to fear any idiots on their phones driving next to you than this
Old Dec 25, 2023 | 08:27 AM
senix's Avatar
senix
I use it when on an incline or when towing. Needless use of it especially in freezing wet snow or water is not when I would use it.
Old Dec 25, 2023 | 08:41 AM
wizardfitz's Avatar
wizardfitz
Not an engineer by any means . I do know when I tried to move after releasing the brake is when I heard the grinding and immediately stopped.
cecilt
Dec 18, 2017 04:58 PM
seventyseven250
2009 - 2014 F150
Jun 2, 2015 10:01 PM
don766
2004 - 2008 F150
Feb 1, 2011 06:37 PM
Ksnarf
Mar 7, 2009 02:32 PM
rferoni
2004 - 2008 F150
15
Jul 4, 2005 10:45 PM
