I recently replaced my weatherstripping and I have a terrible wing window leak now I can’t get the wing windows to push in any more and it’s supposed to rain soon how can I fix this?
It does it on both sides and I assume that the wind noise I posted about is related to this.
In the top picture it does not look like the window is closed and latched. There is a gap between the frame and the seal.
It is closed as far as I can get it to. It is latched.
I was told to put lithium grease on it to help with the gap and I’ll see if I can try that thin weatherstrip and cut it to put it in between.
I was inspecting/using a bottle opener I had to shove the rubber under the window and I saw this hole. Everything is a piece of crap I even got the nice precision seals and it still had a hole. I don’t know if it came like that or it was from install but I do know I was careful putting it on.
The only hole I had in mine was for the post at the bottom to go through. You have to completely disassemble the wing window to replace the seal. I assume that is what you did?
Some info for anyone who does this in the future, what you should do to get the wing windows to close is put some lithium grease on it I used white lithium if that makes a difference. Then you heat it up with a heat gun and push it closed as far as you can and it will seal if it works like mine.
It was closed as in latched. But the gap was still there between the rubber and the window on the outside. So I had to get it to push even farther to close the gap. Cause the gap is gone now between the rubber and the window.
