1978 - 1996 Big Bronco
Power Door Locks
Old Nov 16, 2003 | 08:35 AM
BillyBob69's Avatar
BillyBob69
Power Door Locks
I just replaced my door lock switches and I still have the same probs. The only one that works is the passenger side, and it only unlocks when you push it to the LOCK side. Is this one of those common quirks? If so, is there a certain place I should go look for the prob or am I looking at troubleshooting the wiring from scratch? Also, I looked around in Haynes and I couldnt find anything that told me which wires get power when the switch is used. Did I just miss it or is there somewhere else that I need to go to for this info?
Thanks all!
Old Nov 16, 2003 | 02:18 PM
greystreak92's Avatar
greystreak92
Ok, it only LOCKS when you hit the UNLOCK? Sounds like the switch is either in backwards or you have lost a connection in the switch wiring harness. If the earlier models are the same as later years, the wiring for the driver's side switch passes through the passenger side switch first. So, if there is something wrong with the passenger side switch or it is missing, the driver's side will not work at all.
Old Nov 16, 2003 | 02:35 PM
BillyBob69's Avatar
BillyBob69
I tried the new switch in both ways....Plugs in either way. When you push it to the LOCk side, it unlocks the doors. And only on the passenger side. Drivers side is dead altogether.
Old Nov 16, 2003 | 04:17 PM
treehugger36's Avatar
treehugger36
My drivers side has never locked using the power lock button, since i have had it anyways.
I havent had a problem with the pasenger side... except that it wont unlock my door either. Kinda wish I didnt have power locks... seems kinda pointless with only two doors and no key fob to unlock them from afar. I feel the same way about my power windows up front, I wish I could get rid of them easily.
Old Nov 23, 2003 | 01:31 AM
steve83's Avatar
steve83
You have a bad switch. The passenger switch is the master, so it's killing the driver's switch. When you put a good one in, the driver's will work again.
Old Nov 23, 2003 | 03:18 PM
BillyBob69's Avatar
BillyBob69
Steve83...... But I replaced both of them.
With new ones
Old Nov 23, 2003 | 04:16 PM
BOJOFASO's Avatar
BOJOFASO
is it possible that you spiked the lock motor with reverse polarity and it polarized the motor the wrong way?
Old Nov 23, 2003 | 04:18 PM
BillyBob69's Avatar
BillyBob69
Nope...It was doing this beforee I did any tests on it. The first thing I did was replace the switches on both sides
Old Nov 23, 2003 | 04:20 PM
steve83's Avatar
steve83
Swap them and see what happens. It's easy to buy brand new defective parts, so don't assume they're good just because they're new. Where did they come from? I'm about to add the power door lock page from the '93/94 EVTM to the Diagrams album in my signature link. Your wire colors are probably different from what's shown there, but the circuit is identical.
Here it is. In '92-96 trucks, everything to the R of the dotted lines is in the R door, and the rest spans the dash and is continuous into the driver's door. In '80-91 trucks, there's another connector at the L door, which would be just L of where the fuse comes in at the top.
Old Nov 23, 2003 | 04:22 PM
BillyBob69's Avatar
BillyBob69
Yep did that too. I expect a part to be bad but not 2 side by side. I got em from Jeffs Bronco Graveyard. The prob of it only unlocking and from the passenger side only was why I went to replace them. But theprob is still the same even after the new switches
Old Nov 23, 2003 | 06:53 PM
OJ's toy's Avatar
OJ's toy
BillyBob I had this problem on my low miles 89 found out it just needed some grease is you key hard to turn?may be more resistance than the accuator has muscle. Good Luck
Old Nov 23, 2003 | 07:01 PM
BillyBob69's Avatar
BillyBob69
Nope..key turns easily. No noise or nothing at all except for when I unlock.
Old Nov 23, 2003 | 09:35 PM
steve83's Avatar
steve83
Did you replace the switch bezels, too? They're specific to the door they go in, which means that you need a R bezel for the passenger door and a L bezel for the driver's door. If you're using the wrong bezel, the switch will seem to operate in reverse.
You also have to install the switch in the bezel correctly for the functions to match the labelled directions.
The fact that only the lock function works suggests that the Pk/Y wire or the Bk wire at terminal 11 is broken. Pull the sockets off the switches and inspect the terminals inside them.
Old Nov 24, 2003 | 08:04 AM
BillyBob69's Avatar
BillyBob69
Nope....I haven't switched the bezels yet since I haven't found any. Jeff's Bronco Graveyard didnt have any. As for the switches, they plug in either side either direction. Doesn't matter which switch I use or which direction it goes in , I still get the same prob as I had to start. Will only unlock and only from the pass side, and only when you push in the lock direction. As for the terminals, I went through all the conenctors in both doors and all is ok. they are are clean and make a solid connection.
I do appreciate all the help on this everyone. I think however at this point I am going to have to hunt for a schematic specific to the wiring on my truck. Looks like I get to go spark chasing! Weeeeeeee
Old Nov 24, 2003 | 08:25 PM
steve83's Avatar
steve83
The 36058 Haynes manual has that specific circuit in the '81-83 diagrams. In the last edition with the red cover, it's page 12-29 just below & L of center. In the current edition with the blue cover, it's in the same location on p. 12-28.
