Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F600 wheel options
Old Dec 16, 2023 | 05:57 PM
alfio's Avatar
alfio
F600 wheel options
hello all,
thinking about getting an F600 for a project build. looking at a 1969 with split rims and a couple of other older ones that all have six lug typical medium duty wheels for the period. what modern wheel options fit these? i realize that in some ways the easiest option is to swap out the axles and get modern disc setup and jump into a 10 lug or 8 lug setup. that option aside, what can be done with the 6 bolt drum/ axles? thanks
a.
Old Dec 16, 2023 | 07:02 PM
garygnu's Avatar
garygnu
are there any military rims that would work ?
Old Dec 16, 2023 | 07:15 PM
85e150's Avatar
85e150
Do you have split locking rings, or the two piece widowmaker rims?
Locking ring wheels are safe and servicable, but usually you have have them serviced at a truck tire place and you have to run tubes.
GMC military wheels will work.
Most or all of it is right here:
https://www.ford-trucks.com/forums/8...l#post19892682
Old Dec 17, 2023 | 08:33 AM
alfio's Avatar
alfio
Thanks for the link. Haven't bought the truck yet, researching the build really. I will look into military rims and tires, seems like a decent solution.
a.
Old Jul 13, 2025 | 07:55 AM
danskool's Avatar
danskool
Go Bills !
If you need anything, I work down the road from McGard. I could run over there for you
Old Aug 14, 2025 | 01:38 PM
jholland's Avatar
jholland
I bought an older U-Haul truck cab and chassis that had 9.5 x 22 solid rims on it. Cab was rusted completely out. I paid 500 for it and got the rims and front shock mounts and a practically a new starter of it. Sold the rest for scrap. If you look hard enough they are out there. I took me quite a while to find something.
JHolland
ribich
Sep 6, 2022 06:56 PM
Ole_shaw6
May 30, 2022 09:50 AM
jaker6892
1997 - 2003 F150
Jan 11, 2011 10:01 AM
bo_95f250_4by4hd
Dec 3, 2002 02:03 PM
