Injector issues... #2,4&6 not working 4.9L " 95 " f150
I have95 f150 4.9 #2,4&6 injectors not working have power to them but i can pull corresponding plug wires and no change in motor I have a digital multi tester but not sure what reading exactly to look for or if that type of tester will work for that... FYI I changed engine wiring harness with one out of different year but I checked the wire placement in its connector with the old one and they were the same still has original injector harness took it apart and fixed where the wires were touching each other but worried that it could have already damaged the computer...
any help would be greatly appreciated
have been dealing with elect issues for last year have learned alot about auto elect during it all but far from knowledgeable got a ways to go yet .
A noid light test is in order (checks if the processor is providing the ground when cranking and if the injectors have key on power.
Buy or rent one
You can also make your own or use a DVOM (making the connection is difficult with test leads from a DVOM) that is why using a noid light is the best way IMO.
The 1995 processor should be sequential, not batch fire (or bank 1 and bank 2) I am not positive about your 4.9
Your underhood VECI sticker may say something at the bottom about catalyst type and sequential or SEFI
Sounds like you might have 3 injector drivers that are no good in your processor
Buy or rent one
Received 1,028 Likes
on
I agree, the 6 pop may never have got sequential until OBD2 in 96?
Cardone is where to look for a replacement processor
Get the tag numbers off yours and search by the numbers
Mine was JAG1 for my trucks calibration
I found a brand new one for just under 400 bucks and now sleep well
Also, less grief on long road trips
The following users liked this post:
Right, so he has 3 drivers out in his processor which does seem a little strange?
In screwell they used Lincolns and SHO Taurus as test vehicles
The Super Coupes and the like, they were all new technology when I was going through the stinkin maters program
That masters cert and 50 cents will buy you a cup of coffee
Hard knocks is the real school you attend for life
Bill . B
Site Announcements
12-16-2023 02:32 PM
