Radius arm bushings
Old Dec 16, 2023 | 07:04 AM
egchewy's Avatar
egchewy
Radius arm bushings
Replacing radius arm bushings on a 79 f150 4x4. Got the poly bushing kit. Do I need that nylon spacer on the rear radius arm bushings, or am I good just using the cupped washers? Original spacers nowhere to be found.
Old Dec 16, 2023 | 07:50 AM
ranger140892's Avatar
ranger140892
Grumpy goat
I've replace them on a few 78-79 trucks and Bronco's. I don't remember any spacers. Just five parts on each side. From front to rear: Cupped washer, front bushing, rear bushing, cupped washer, and the nut.
Old Dec 16, 2023 | 09:24 AM
egchewy's Avatar
egchewy
thanks, that’s what the LMC diagram suggests too. The front and rear bushings look the same. In other model years, they were a bit different with a nylon spacer between the body mount and the rear bushing. I’ll take a look today to see if there’s a large amount of play between the bushings that should be taken up by a spacer
Old Dec 16, 2023 | 09:52 AM
tbear853's Avatar
tbear853
I've got a set on hand to put in, but haven't yet. There's no added spacer in my set. I did all the other poly with a 14 piece set over 30 years ago, recently did the trac bar again, but still have the OEM bushings there at the rear of the radius arms.
Is the spacer like a really thick flat washer to take up space lengthwise ... or is it ... like a tube preventing contact steel radius arm long rear shaft to steel frame bracket?
Did you use straight poly replacement C bushings, or did you opt for some with added degrees of caster added.
Old Dec 16, 2023 | 04:25 PM
egchewy's Avatar
egchewy
Ok, checked instructions again and no spacers for the 79s. Mission accomplished.
Old Dec 16, 2023 | 05:14 PM
ranger140892
Grumpy goat
Woo Hoo!
I see you installed new C bushings also. Have you noticed how much better it steers? Mine improved a lot.
Old Dec 16, 2023 | 08:47 PM
egchewy's Avatar
egchewy
Woo Hoo!
I’ll let you know. I’m still months away from being road worthy. Pics don’t show it, but currently no motor on the rig. Have a rebuilt 400 sitting on a stand right now waiting to be installed. I figured it’d be easier working on the front suspension while the motor was out. The C bushings were fun to install, especially when you snap off a spring cup bolt that goes into the radius arm. Had to drill out the bolt and retap the hole.
Old Dec 17, 2023 | 08:19 AM
ranger140892
Grumpy goat
Yeah, getting the first coil spring back in is easy. But once it's installed, the other side is under tension, and it's difficult to line up the two bolts in the cup. I experienced that when I installed new C bushings. A couple of years later, I decided to change coil springs. I dreaded fighting those spring cup bolts. I ended up getting a set of aftermarket spring cups from Duff. Those things made the swap a total breeze!
https://dufftuff.com/product/heavy-d...-dana-44-pair/
Old Dec 17, 2023 | 02:39 PM
egchewy's Avatar
egchewy
nice. Cups and retainers combined. Wish I knew about these a few weeks ago.
Old Dec 18, 2023 | 10:23 AM
egchewy's Avatar
egchewy
just saw this part of your post.
I used the 2* C bushings for stock height. not lifting this truck.
Old Dec 18, 2023 | 05:27 PM
tbear853's Avatar
tbear853
What I did. Was either 2 or 4 degrees ... vague memory ... but it immediately improved road manners with the extra caster.
dogohio
Aug 21, 2013 09:28 AM
OffRoadF-150
Offroad & 4x4
Jan 4, 2006 01:32 PM
geowing
Oct 9, 2004 01:55 AM
Toy man
Sep 18, 2002 07:43 PM
