Aod-e swap for an aod
Old Dec 15, 2023 | 06:23 AM
Godhelpusall's Avatar
Godhelpusall
1st Gear
I have a 1994 f150 with an aod-e transmission can I put an aod from a 89 f150 in it?
Old Dec 15, 2023 | 08:38 AM
jas88's Avatar
jas88
Yes, but you will need to include the linkage for the TPS cable or linkage from the throttle to the trans. Also be aware your ECU is gonna set codes complaining that the trans is not talking to it.
Old Dec 15, 2023 | 10:43 AM
85e150's Avatar
85e150
AOD E and 4R70 are improved versions of the AOD. Much improved.
Something gone wrong with your setup?
Old Dec 15, 2023 | 12:58 PM
Hit Man X's Avatar
Hit Man X
Gonna guess the forward clutch pack is roached in that 70W.
If one has skill enough to R&R a trans, one can replace the forward clutches in these. I would have the converter rebuilt while out, mild shift kit, and motor on.
Seanmac1007
Sep 4, 2023 01:56 PM
Jbremenek
Nov 23, 2022 07:51 AM
460guy
Oct 31, 2002 05:14 PM
Chris1368
May 1, 2002 12:43 PM
