56 Radiator Support ?
Old Dec 13, 2023 | 02:22 PM
blake in spokane's Avatar
blake in spokane
Questions about my LMC radiator support bolts & pads. My original has 2 studs in the middle for front to back adjustment the, LMC has carriage bolts - do I drill out the studs & use thru bolts ? Next is the 2 side pads, original bolted up thru the bottom of the support frame & rested on the cross member, the LMC has carriage bolts that go thru the rubber pads & thru to the bottom of the cross member with no adjustment. + Back to the center bolts, the bolt holes in the rubber pad and steel plates are about 1/8 narrower. Last question " rubber pad on top inside support & one rubber pad between bottom support & crossmember ? Steel pieces ?
jeff gammon
2004 - 2008 F150
Feb 6, 2015 07:43 PM
dotcentral
Nov 11, 2012 06:02 PM
chappys4life
Apr 1, 2012 04:09 PM
53OlderThanMe
13
Oct 15, 2007 10:15 PM
f1fordguy
Jul 4, 2002 10:40 AM
