My last 2 all aluminum radiators developed pin holes within a few months - 2nd radiator was a warranty replacement - that developed pin hole leaks too.
Bars stop leak worked for a while but eventually the 2nd radiator leaked again.
Radiator repair shop pressure tested and said the radiator was unrepairable due to too many points leaking on both sides at the tanks.
What manufactures/brands are recommended?
Or should I just go with the cheaper plastic side tank variety?
