The big black stock sensors that stick out 2” from the truck are getting slaughtered with rocks, they’re paper thin, 1200 Canadian dollars to replace and I’ve cracked my second one.
morimoto led says they won’t have anything till Q2
Ford can’t tell me if the 2024 led tail lights can work in the 2023, I assume not without a wiring conversion.
What is everyone doing out there, I can’t find much info, but with only 10,000 km on the truck and two tail lights cracked I can’t be the only one needing a solution
I see this is your first post here. If you're allowed do a forum search on Morimoto. Mixed reviews on their quality. I'd guess more negative than positive on this forum.
I’m not stuck on morimoto, but I have a 5 year old set in my 2012 that still work great and they’re the only manufacturer that has actually emailed me back, so at least there costumer service is good. Any solution or manufacturer will work at this point. I did a few searches and couldn’t find any useful info for this situation , thanks for the reply
