2024 F-350 Initial Thoughts
Old Dec 13, 2023 | 08:48 AM
mitch8628's Avatar
mitch8628
I picked up my new 2024 F-350 CCLB Lariat Ultimate on Monday at Granger. I live in Northern Wisconsin, so it was a 500 mile drive home with a pit stop in Madison, WI for some meetings on Tuesday. Here are my initial thoughts so far with the 2024. Keep in mind, I came from essentially the same truck but a 2022 in a short box which I put 36,000 miles on in 2 years.
  • I am liking the heads up display and new instrument cluster display.
  • The instrument cluster is very customizable. I was able to turn on the coolant and trans detailed temps on the guages. Also display the DEF gauge alongside the fuel gauge.
  • I like the HUD display for normal driving, the tow mode, and offroad mode. Nice to have different things to see depending on the mode of driving.
  • Many of the options I changed for the 2022 Lariat Ultimate using ForScan are now available to change as settings in either the instrument cluster settings or the Sync screen settings
    • Double honk on exit
    • Auto fold mirrors
    • Temps on Gauges
    • DPF % (comes with an integrate gauge)
  • ForSCAN options I still want to apply
    • Turn Signal Flash Count
    • Disable all seatbelt chimes
    • Potential new tire sizes
  • Truck rides just like the 2022. I honestly don't notice much a difference.
  • Steering wheel grip feels thinner. OVerall I like it. Buttons are different on the steering wheel.
  • I like the console changes. I can actually use the wireless charger. Also the spot to set the phones/slot to set the phones works great. Also, my Yeti water bottle actually fits in the cup holders. Downside, is the storage in the console is smaller.
  • So far after 500 miles, the transmission is much smoother, shifts better than the 2022.
  • I'm not sure on the stock tire change. I really liked the Michelin LTX A/T 2's on my last 2 trucks. The 2024 came with Bridgestone Dueller A/T's. Makes me want to upgrade them to either the BFG or the new Micheline LTX Platinum in a 295/65/20. But if we can't change the tire size using ForScan.....maybe a Ford Dealer can?
Bad:
- Door interior panels squeak when opening and closing the door. Also, when my leg rests against it it squeaks. Annoying. Seems cheap
- New console plastic squeaks when grabbed touched. Seems cheap.
- I can't seem to figure out the climate control. The past 2022, I was usually able to set climate control to 69 degrees F on both drivers and passenger side and it was just fine. The 400+ miles down to Granger this is how I set. ON the way back in the 2024, I found myself hot and sweaty often. I ended up having to set the drivers side to 64 or 65 and the passenger side to 72 or 73 to get to an almost comfortable setting. Still not perfect.
On my way home last night, I did a quick video.
Old Dec 13, 2023 | 09:06 AM
Erie660's Avatar
Erie660
    • Auto fold mirrors
    • Temps on Gauges
Bad:
On my way home last night, I did a quick video. YouTube Video
Nice review. I also took delivery on the same truck, except I have the XLT premium package. Do you know if I can display the Def gauge like you did on my XLT? I agree this truck rides nice for being a F-350. My buddy says it rides a lot better than his wife’s 2500 Chevy diesel.
Old Dec 13, 2023 | 09:14 AM
RandyinTN's Avatar
RandyinTN
When not towing or carrying a bunch of weight drop the tire pressures to 55 front and 45 rear and the ride improves tremendously
Old Dec 13, 2023 | 09:27 AM
Peej11's Avatar
Peej11
Glad the auto-fold can be tweaked. That was the first thing I wanted to use Forscan for. I am hoping Forscan will work for the turn signal adjustment as I would like to do that as well.
Old Dec 13, 2023 | 09:28 AM
capt caper's Avatar
capt caper
I always owned Lariets. Last one 2019 F350 sb cc . 6.7. I love this 2024 xlt. For me the steering is way easier to handle then the 2019. Seats are much more comfortable as well. I just did 350miles and from 8.30 am to 9pm in the truck waiting for plane to land yesterday and felt like I could go on for many more. On my 19 I my butt would of been hurting bad by then. Arms cursing the 19's steering firmness.
Buttons after 900 miles now still confusing but I'm getting there. I average 40k a year so it won't be long I'm a pro at it.
Old Dec 13, 2023 | 09:02 PM
sbechtold's Avatar
sbechtold
I took delivery of my 2024 F350 on Sunday and I agree with your assessment. My 55 gallons titan fuel tank is sitting in the garage ready to be installed. I'm hoping Forscan will be available for our trucks. I need to update the tank size to correct the DTE.
I'm coming from a 17 Platinum F250. I was concerned about the ride of the F350 being too stiff. To my surprise the F350 rides just as nice if not better than my F250. I did drop the rear tire pressure from 80 psi to 65 psi.
The F350 turning radius is better than my 17 F250. The infotainment system is really nice, but not as nice as other cars/trucks. You guys are going to hate me for this, but I had a Rivian truck for about a year. The driver experience and infotainment in the Rivian was awesome.
I need to spend more time playing with the settings, but so far I'm super happy with my new truck.
Old Dec 14, 2023 | 12:28 AM
twobelugas's Avatar
twobelugas
If more SD owners did this, there would be a lot less business for the aftermarket suspension makers. I set mine to 50 front and 45 rear when not loaded and it rides like a 1/2 ton.
Old Dec 14, 2023 | 07:32 AM
jackfordsd350's Avatar
jackfordsd350
The seatbelt chime could be stopped with a quick procedure using the seatbelt clicks. Saw this on a you tube last week and it worked on my 22.
Old Dec 14, 2023 | 07:56 AM
mitch8628's Avatar
mitch8628
Yeah, there is a procedure in the owners manual. First step is to wait for the seat belt light to turn off. I've waited multiple minutes and it has yet to turn off. Per the owners manual, should be a "short period."
Old Dec 14, 2023 | 11:36 AM
OBS460's Avatar
OBS460
FORscan isn't going to be supported for 2024 and up according to a post Zoodad made.
https://www.ford-trucks.com/forums/1742175-forscan-support-for-my24.html
Old Dec 14, 2023 | 11:47 AM
redford's Avatar
redford
FTE Leadership Emeritus
Sorry that you had to stop in Madison, to spoil an otherwise great road trip.
Old Dec 14, 2023 | 12:21 PM
mitch8628's Avatar
mitch8628
https://www.ford-trucks.com/forums/1...-for-my24.html
I saw that. I was digging on the ForScan forums and found a post that a person made that had some good points. See below:
Originally Posted by Forscan Forums
Now note this particular line:We currently work on adding support for Ford 2023MY models, v2.3.51 should already cover majority of them. Ford 2024+MY models will not be supported.
The 2.3.51 FORScan version being referred to was released in Feb 2023 and is thought to cover majority of 2023 Models(note "that we work on it" and also note there have been 6 release versions since {latest is 2.3.57 and 2.4.9beta}) We are just beginning to see 2024 model posts on the Forum and I doubt that the FORScan team had yet to see any 2024 vehicles Physically(their Country is being sanctioned by the way) or seeing support requests for 2024 vehicles by the time of the 2.3.51 release and at the time this statement was likely written!
One could read this line as FORScan Version 2.3.51 will not have any support for the 2024+MY! This line may or may not imply no support for 2024 but the wording does not explicitly say that there will not ever be 2024+MY support in future releases, it likely just says no 2024+MY support in this 2.3.51 version!
One could email the team and ask about this rather than debating this on the Forum!?!
Having been with the FORScan program since its release onto the web in 2010/2011 and on this Forum ever since it opened in 2014, I find it hard to believe that there would be no FORScan support for any future FORD models unless FORD actually does something to prevent it like encrypting the Data(some Manufactures already do this or are threatening to
{John Deer has been in threatened with Farm group class action over this}), We should probably consider ourselves lucky Ford has not done so up to the present!
Also, do not forget that English is not the team's first language and the real meaning can get lost in the translation from Russian sentence structure into English(Original Meaning could have been, FORScan version 2.3.51 will not have support for 2024+MY)!
And as Don Ridley and oldtinfords have pointed out it takes time and physical access(2024 Fords May be rather scarce in Russia currently under sanctions) and/or, at the very least, enough Log and dump.bins files from Licensed Forum members with the 2024+MY vehicles to get any movement on future support for the appropriate vehicles! Therefore it my take a year and several versions!
Notice in the Change logs(https://forscan.org/changes_history.html) that it has taken almost a year and 6/7 versions to get 2023 mostly nailed down and we are still seeing some Posts from members with 2023 vehicles having connection issues!
Just my observation and I have been known to be wrong. Would very much like not to be wrong in this case! For what it is worth!
Old Dec 17, 2023 | 07:06 PM
mitch8628's Avatar
mitch8628
Just some follow up:
I was able to eliminate the squeaks in the door panel and console. I used some CRC Power Lube and lightly sprayed it in the joints of the plastic. The squeaking was from where all the plastic parts rubbed together slightly. After a day, no more squeaks.
One thing I'm disappointed about, I fully 100% expected a 3" shank hitch. My 2022 F-350 Ultimate Lariat had a 3" and never thought that Ford would turn back, but looking back, that was idiotic of me. Ford seems to like to change things just to change them. Blahhhh...Now I need to attempt to sell my 3" bulletproof hitch and get a 2.5".
I did get my Gatorback mudflaps installed. The engineers at Truck Hardware are really making the install process a lot easier. I installed a set on a 2006, 2022, and now the 2024 and the 2024 was the easiest yet.
One last thing, I didn't expect different wheels on the 2024, but never thought much about it. I don't really enjoy the design change compared to what was on my 2022 Ultimate lariat and on 2023 King Ranches. So now I have my eyes on swapping the wheels and tires (I "photoshopped" in the modified tires in the last image).
Old Dec 17, 2023 | 07:34 PM
Rwhjr's Avatar
Rwhjr
nice looking truck….I vote to keep the 23 wheels on. They look better than the old ones you photoshopped on.
DaleGolds
Nov 10, 2023 06:54 AM
Yanmar
Sep 20, 2023 03:13 PM
Vintage Chief
Electrical Systems/Wiring
Aug 20, 2020 08:01 PM
90pioneer
Mar 13, 2013 09:24 PM
85351ho
Oct 24, 2002 06:28 PM
