Tach does not work for about 5 min
Old Dec 11, 2023 | 01:56 PM
BlueBetty350's Avatar
BlueBetty350
2nd Gear
Anybody have a wiring diagram for a 1990 F350 Dually Diesel?
my tack does not read for about 5 min when starting cold and it shifts like crap when tach inop also when Tach is not working I can not active the overdrive switch. once the Tach comes on it shifts pretty normal and the O/D switch works..I cant see a reason for the Tach to not come on right away. any help???
Old Dec 11, 2023 | 02:06 PM
tjc transport's Avatar
tjc transport
i ain't rite
the trans needs tach signal to shift properly. so no tach signal, no shift.
try taking the tach sensor out of the timing cover and cleaning it.
Old Dec 11, 2023 | 03:31 PM
BlueBetty350
2nd Gear
sorry I forgot to mention that I replaced the Tach sensor with a new one and it dint change a thing...
Old Dec 12, 2023 | 10:47 AM
Scott in TX's Avatar
Scott in TX
do you know the replacement works or you don't have a bad connection ???
I had the same problem, cold-no tach reading, shifting problems, after warmed up tach works, I replaced the tach sensor and truck ran fine,
Rxracer27
Jul 22, 2012 04:47 PM
wally2117
Electrical Systems/Wiring
Jul 16, 2002 11:35 PM
