rough ride
Old Nov 22, 2003 | 11:12 PM
realgronk's Avatar
realgronk
Question rough ride
I bought a 1993 F250 XLT SC 4x4 460 a few months back. it has 140,000 kilometers and rides as rough as can be. We been through the front end replacing anything that looked bad and also replaced the front shocks. Still rides like an old tank. Its got fairly good michelan tires 10 ply. Is this just the nature of the beast or are we missing something? Thanks in advance for the help.
Old Nov 23, 2003 | 07:00 AM
First Ford Truck's Avatar
First Ford Truck
The 10 ply tires can be a good reason for the ride theyre probably a load rage e or more. You can try to lower the air pressure to soften the ride some. Try 35 psi front and 30 psi rear. When you are hauling or towing air up the rear to 35 psi. When you need new tires go for a load range of D if you use it as a 3/4 ton or C if you it is used more like a half ton. You may not be able to find C in your tire size though.
kent521
Mar 11, 2011 09:46 AM
H8monday
Offroad & 4x4
52
Aug 19, 2010 08:33 PM
garymake
Dec 13, 2002 03:10 PM
rjcantin
1997 - 2003 F150
Sep 26, 2001 06:07 PM
