96 4.9 mpg
Old Dec 17, 2023 | 06:12 PM
Mudsport96's Avatar
Mudsport96
Ok well that makes sense. I wasn't sure if you used liters or that imperial gallon. Ok. Well 11-12 isn't great but not horrible. It could be that the higher pressure from the new pump is causing leaky injectors hence the lower mpg. Could be that the fuel pressure regulator is getting weak or seeping across the diaphragm.
Old Dec 17, 2023 | 07:04 PM
Ronniewhite's Avatar
Ronniewhite
ok well I will keep a eye on it. If it starts getting worse i will get my mechanic to look at it.
Old Dec 17, 2023 | 07:27 PM
Mudsport96's Avatar
Mudsport96
Have you checked for codes?
Old Dec 18, 2023 | 12:13 AM
Ronniewhite
ya don't have any.
Ronniewhite
Mar 17, 2022 11:42 PM
Ronniewhite
Mar 17, 2022 10:52 PM
Baxtjh
33
Jun 22, 2010 11:29 PM
Hotter
Jun 4, 2004 08:33 AM
Hotter
May 28, 2004 07:54 AM
