Purchasing First Excursion
Old Dec 9, 2023 | 07:53 AM
oldman51311's Avatar
oldman51311
6th Gear
I plan to purchase my first Excursion in the next few weeks. I have driven Super Duties for the past thirty years with both diesel and gas engines. I have several I am looking at but looking for the opinion of others. All are Limited models with 110,000 to 130,000 miles. They are a 2002 7.3, a 2004 6.8, and a 2005 6.0. With all other things being equal, which would you choose and why?
Thank you
Old Dec 9, 2023 | 10:03 AM
WE3ZS's Avatar
WE3ZS
Welcome to the EX forum!
Personally, I won’t buy anything that is rusty and that is a hard line for me. Hopefully you are in the South or SW and have access to nice rust free EXs.
You have experience with both the gas and diesel choices in your past pickups, I would lean heavily on those experiences as to which way to go on the EX. Personally, I would go gas for the same reasons now as I did 13.5 years ago when I bought my EX, I have other hobbies so I don’t need or want to be under the hood of a PSD frequently. My 6.8 has needed a fuel pump as the only engine related repair over my time with it which has included 85K heavy towing miles (9,500 to 13,000 lbs of TH/TT). Many others here have had very similar ownership results with both 7.3 and 6.0 wagons. Good luck on your choice and future EX!
Old Dec 9, 2023 | 10:31 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
I second the 6.8 for what WE3ZS posted. Purchasing a very reliable/easy to work on drivetrain is a big plus.
Also, you are going to need that extra cash in your wallet because after 20 years of existence, unless the previous owner did some work, you are going to need to replace all sorts of stuff:
Steering components
Springs
Bushings
Bearings
The list goes on and on.
Our Ex is a pavement pounder and we purchased the Ex with that in mind, so we installed a TrueTrac limited slip with 4:56 gears. We have never gotten stuck in 24 years of ownership. The 4x4 is great for trails, but if you are a roadmaster, you can save yourself some maintenance cash and time, as well.
Old Dec 9, 2023 | 02:08 PM
rsqfxr's Avatar
rsqfxr
Whil
Thank you
IMO and experience, the 7.3 for reliability and decent towing fuel mileage
Old Dec 10, 2023 | 09:03 AM
bwguardian's Avatar
bwguardian
Thank you
Where are you located? What will you be using the Excursion for? Do you know the maintenance history of the 6.0L?
Old Dec 10, 2023 | 10:51 AM
oldman51311
6th Gear
First Excursion
Thank you for your replay. I live in North East Tennessee, I am a Realtor and specialize in land sales. I plan to use the vehicle to carry clients while showing property. We are in the mountains an 4x4 is necessary.
Old Dec 11, 2023 | 01:55 PM
Ted722's Avatar
Ted722
Definitely could make a case for either one based on need and preference. I bought my '03 V10 (92K miles) a couple years ago because I was intrigued with the engine (a couple motorhome rentals w/V10s) and ultimately wanted an old school truck with that engine. 2 years later still enjoy driving it, towing with it, and hearing it. Yes, like that V10 tone and power delivery. Other than regular maintenance, only major thing I've done is a gear ratio change.
Not sure if you found it yet, but this guy compares those exact engine combinations you're interested in. Some good tidbits of info, he likes them all too, and makes a case for each one based on usage, etc.(click on watch on youtube as unable to embed here)
Old Dec 11, 2023 | 08:24 PM
John in OkieLand's Avatar
John in OkieLand
IF,
your wallet is not overly blessed with overflow, I suggest going with a gas rig.
I have enough retirement savings to afford a play truck, I have a Suburban now, but it is a dullard pulling our 8k 27ft RV, and on the last trip, the rear Diff locked up. I used that as "an excuse" to buy my '02 7.3L Excursion.
follow my signature link to see what I have poured into the Rabbit hole.
you will have to zoom in to read the text.
my biggest splurge was the electric hide away steps, gawd they are a blessing, and the TrueTrac locker rear diff, and gawdly expensive aluminum rear diff cover so I could drain the fluids w/o removing the cover...
the 4x4 is rough rider...
just noticed, that my last rabbit hole investment is not listed,
I bought a full bushing kit, and had it installed locally.
oh boy, did that get rid of a lot of squeaks and looseness in the body fill.
Pele
Aug 22, 2022 09:22 PM
northernsnooker
Mar 23, 2010 10:19 PM
frogman434
Oct 21, 2008 03:20 PM
4x4 VANMAN
Oct 13, 2005 06:11 PM
