94 Explorer Emergency Brake Cable installation
Old Nov 22, 2003 | 09:39 PM
daring's Avatar
daring
Unhappy 94 Explorer Emergency Brake Cable installation
Briefly, the front-most third of the emergency brake
cable broke. I arranged for a replacement via the
internet for 20% of the dealer cost. (I'm paying for
it in frustration now.)
Anyway, I had to take the brake lever unit off the
kick panel to get the old cable out and new cable
in, but now that everything's back together, the
cable isn't long enough for me to clip the front
cable to the intermediate one.
Oh, I've already learned about the spring-loaded
brake level assembly...I inadvertantly pulled the
little plastic wedge out and WHACK! But it's back
in there, now.
I can't seem to get enough slack to put it back
together at the brake lever or between the front
and intermediate cables. Is this done by opening
up the rear drums?
What's the trick on this repair?
Old Nov 26, 2003 | 09:08 AM
daring's Avatar
daring
Have I stumped the forum?
Old Dec 5, 2003 | 12:10 AM
daring's Avatar
daring
Talking 94 Explorer Emergency Brake Cable installation
Well kids, the mystery is solved. Bottom line on this
repair: as the Chilton manual describes, you must
fashion yourself a tool which holds the forward-
wound spring-loaded brake assembly mechanism
in place so you can link the brake cable under the
vehicle. Once connected, you can remove the tool
to take up the tension in the spring-loaded mech-
anism, then re-attach the assembly to the kick-
panel. Pix:
pamante
Jun 10, 2019 12:26 PM
BigSix1
Mar 13, 2017 03:54 PM
powerstroker100
Aug 17, 2015 01:16 PM
Mark VII
Aug 9, 2015 09:29 PM
aldrowsboy
Aug 14, 2013 11:06 PM
