1952 Hood
Old Dec 6, 2023 | 07:37 AM
ReidVi's Avatar
ReidVi
Trailering
1952 Hood
Good morning, I need some feed back. i have attached two pictures one of my truck and one of one I found on facebook. Which one is the correct hood for a 52?
Picture on FB
My 52 -F3
Old Dec 6, 2023 | 07:40 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Top one. The second is a 51. But there might be more to this. I have a 51, came to me all original with original title showing it as a 52. Some states titled a vehicle as the year it was sold. In my case a late 51 built in Louisville got shipped to Indy for MH conversion, then shipped to Idaho, sold, and titled as a 52. Your serial number will give the truest answer. And you’ll want to figure out if a prior owner replaced the hood. Stu
Old Dec 6, 2023 | 07:58 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
It should also be noted that the top one has been outfitted with the 5 star trim additions. Now, additionally, Victor's truck is Canadian, and I don't have a Canadian book for 52 right at my fingertips to check if they followed through (I would suspect they did eventually, but Victor's engine is purportedly a 51 manufacture, implying this is an early 52)
Old Dec 6, 2023 | 08:08 AM
ReidVi's Avatar
ReidVi
Trailering
Thanks, my vin # number say's 52. you are correct it is a Canadian truck so it could be a early 52. I have noticed the difference in the hoods before so it just got me curious.
Thanks again for the quick replies.
Old Dec 6, 2023 | 09:34 AM
52 Merc's Avatar
52 Merc
Your truck has more than just a 51 hood, but the grille header panel with the V8 emblem, just below the hood, matches as a 51 part also. If your serial number reads AHP in the middle of it, to denote a 52 model, one could presume the likelyhood of it being damaged at some point and receiving a replacement front clip from a used 51. Early 52 or not, it would not have received the wrong parts from the factory.
Old Dec 6, 2023 | 10:15 AM
ReidVi's Avatar
ReidVi
Trailering
Hello, my serial number does have a AHP in it. Serial# DFA81AHP-7633, my ownership is for a 52 so I am going with a 52 with 51 front clip on it.
Engine IP-3654
Victor
Old Dec 6, 2023 | 10:17 AM
mtflat's Avatar
mtflat
As Wayne is describing, one of Ford's quirks was 48-50 and 52 had the letters F O R D below the hood with the V8/I6 medallion on the hood. 1951 only moved FORD to the hood with the engine medallion on the upper valance.
AHP
A is standard cab
H is Home office assembly plant Ontario
P is 1952
Old Dec 7, 2023 | 04:46 PM
52Flthed's Avatar
52Flthed
Picture on FB
My 52 -F3
your truck looks great- love the accessories.
Old Dec 7, 2023 | 04:53 PM
bigwin56f100's Avatar
bigwin56f100
I'm not fluent in the 51-52 trucks but I thought the motor mounts were different between the 2 years
Old Dec 7, 2023 | 05:32 PM
52Flthed's Avatar
52Flthed
I think you’re right I remember that being pointed out.
Old Dec 7, 2023 | 06:05 PM
bigwin56f100
I thought it was the front frame/engine mounts that were different. But I wouldn't know one from another
Old Dec 7, 2023 | 10:26 PM
badboyjcs's Avatar
badboyjcs
Are the hoods actually different between 51 and 52 or just the trim piece on the front.
Old Dec 7, 2023 | 10:42 PM
bmoran4's Avatar
bmoran4
The hood panel is actually different, but the later Ford part books considered them interchangeable 48/52.
Old Dec 7, 2023 | 11:04 PM
truckdog62563
The 51 is open across the three nose ducts while the 52 is blanked in the middle area.
The motor mount frame members in 52 were angled to accommodate the new OHV 215 engine. There are also captive nuts at the base of the firewall to mount the 215 carb linkage. Stu
Old Dec 7, 2023 | 11:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The '51 hood spears and nose piece are different than '52's, so you'd want to change the whole hood with trim, but they physically interchange.
The brackets that the motor mounts bolt to are the same from 48 - 51, different for 52 to accommodate the new 215" 6-cyl that came out in 52.
48-51 motor mount:
52 motor mount:
