Slightly bent pushrods
Old Dec 7, 2023 | 07:38 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Originally Posted by DanielT28
I made sure to have the engine at the 11 o’clock position. I did not use an Impact. But I did use an electric ratchet. What I did was tighten until bolt made contact with the rocker. Then tightened the rest of the way by hand.
so I probably screwed myself over? Should I remove all of them again and check? The only instructions I could find stated to have the engine at 11 o’clock position. I hope I didn’t further damage anything else
If the mark was at 11 o'clock or close to it, then it shouldn't matter how fast the rocker arms were bolted down. By the time the engine would be ready to run, the lifters would (or should) be collapsed anyway.
No telling what you've got going on.
Old Dec 7, 2023 | 07:42 AM
96SD's Avatar
96SD
Hollow sound sounds almost like something is tapping the cover
Old Dec 7, 2023 | 07:44 AM
DanielT28's Avatar
DanielT28
frustrating part is I did have this noise come from the intake in the past. But it would mysteriously come around for a few minutes and then go away. Like once a month at most. It was never consistent. I just attributed it to a random misfire. Or timing was off or something cause like I said it would go away.
i was just trying to basically do preventive maintenance and figure out why my truck smokes so much on cold start. I came across a video online of a guy with the same noise out of his intake and he had a broken pushrod. So I decided to check all of mine.. here we are. Trying to fix things and I made them worse. And screw them up. .
the only other thing I did do and I just remembered is I re torqued the injector hold down bolts. I replaced my injectors in July. 120 inch pounds.
Old Dec 7, 2023 | 07:46 AM
DanielT28's Avatar
DanielT28
yeah. It was definitely not doing this before I did this “preventative maintenance” to it. WTF 🤬 😱
Old Dec 7, 2023 | 08:33 AM
DanielT28's Avatar
DanielT28
With the valve covers off and the intake off there is no noise either
Old Dec 7, 2023 | 08:45 AM
knottyrope's Avatar
knottyrope
mine sounded like that this morning
was cold out today at 23 and smoked a lot too
Old Dec 7, 2023 | 08:48 AM
DanielT28's Avatar
DanielT28
lol. Maybe I should just drive it. I drove it for 20 minutes and it never got better
Old Dec 7, 2023 | 09:01 AM
knottyrope's Avatar
knottyrope
I have a tick on drivers side now too.
making me wonder if pushrod is going on me now
If you had a badly bent push rod and inserted a new one with out pumping down the lifter, valve could hit piston
Old Dec 7, 2023 | 09:02 AM
DanielT28's Avatar
DanielT28
none of them were badly bent at all. They were slightly bent. When I rolled them on the table. You could just hear a difference and see a slight difference
As they were rolling.
assuming we’re working with thousants of inches. I suppose when I used the electric ratchet I could have bent them. . I’m going to get new ones and replace them by hand. Hope it goes well.
Old Dec 7, 2023 | 11:37 AM
DanielT28's Avatar
DanielT28
what do you mean pumping the lifter?
Old Dec 7, 2023 | 12:31 PM
Hit Man X's Avatar
Hit Man X
Ever do a compression test?
Diesels smoke when cold due to incomplete combustion usually.
Old Dec 7, 2023 | 12:33 PM
DanielT28's Avatar
DanielT28
I’m going to use a buddies tester here soon
but I read that if the valves are not setting correctly the compression test could be incorrect.?
Old Dec 9, 2023 | 12:29 PM
  #28
DanielT28's Avatar
DanielT28
Replaced all of them again with OEM parts same noise, decided to unplug each injector with the engine running and number eight is doing nothing when I unplug it. I can do a buzz test but something is not working. I already checked the ohms with the IDM plug and it OHMed out fine.
Old Dec 10, 2023 | 11:19 AM
  #29
timrothschild1's Avatar
timrothschild1
It does not matter. Either way leave the glow plugs out until last. When ready to reinstall, put valve covers on with 2 bolts, Spin motor with key a few times to purge any and all fluids from top of pistons. Always do this if injectors or glow plugs are removed. Also make sure the timing mark is lined up with CPS (11 o'clock position) before torquing rocker arms. Good luck
Old Dec 10, 2023 | 11:20 AM
  #30
DanielT28's Avatar
DanielT28
it seems that I have low compression in cylinder 8 either the engines messed up now or a valve is messed up. Or both. I don’t know how it happened or what I did. I swapped #8 and #4 injector ran it and have the same issue. Guess I’m going to pull the head off. Thinking to just rebuild the dang thing. $$$ is an issue though. 😱
