locking cam assembly
Old Nov 22, 2003 | 08:13 PM
jbain2's Avatar
jbain2
Today I tried to change out the rotors on my 92 Exp with Auto locking hubs. Got everything off fine but I can't seem to get the locking cam assembly back on. I know that they are spring loaded. Is there some kind of trick to this. Changing rotors should be this hard.
Also, I figured while I had the front wheels off I might as well change the shocks. I torqued the bottom mount bolt and it sheared off. I called Ford and they said that I had to purchase the entire lower radius arm. Is this true or can I just replace the bolt?
Thanks.
Old Nov 22, 2003 | 10:56 PM
mrshorty's Avatar
mrshorty
It's been a while (converted to manual hubs a couple of years ago), but if I remember right, it's simply a matter of forcing it to slide over the bearing locknut. If I remember right, it wasn't easy because that cam fits real tight over the locknut.
Old Nov 23, 2003 | 10:54 AM
jbain2's Avatar
jbain2
I worked at it for an hour. Tried removing the retaining springs and then putting them back on after the cam was on, but couldn't get them over the cam. Thanks for the reply.
Caveman2851
Dec 8, 2010 01:24 PM
tom2131968
1978 - 1996 Big Bronco
Aug 14, 2006 11:21 AM
1989ford250xlt
Aug 2, 2005 11:27 AM
lukedraper
Apr 5, 2005 08:30 PM
BiteUrFace
Nov 11, 2004 06:00 PM
