MOVED TO APPROPRIATE THREAD
Old Mar 6, 2023 | 12:41 PM
oldcoupe42's Avatar
oldcoupe42
So I have this used Craftsman model 536.889252 Snow blower and its a nice higher end heavy duty machine but after using it twice the drive wheels no longer go forward or reverse (It just "freewheels")
On most Hydrostatic Lawn tractors there's a transmission disengage Pin in the back that allows you to move them when performing maintenance but I don't see anything like that on my Snow Blower.
Hoping someone knows about these as I've never owned one and maybe that's what caused the drive function to quit working?
Regards, Chet
Old Mar 6, 2023 | 02:51 PM
moejr's Avatar
moejr
Sounds like the belt broke or you need to adjust the drive cable.
Old Mar 6, 2023 | 04:55 PM
tjc transport's Avatar
tjc transport
i ain't rite
there should be a drive pin on each wheel that goes through the axle.
there is also two drive belts. one for the blower, and one for the drive.
Old Mar 6, 2023 | 05:51 PM
RLXXI's Avatar
RLXXI
Needs to be moved into general NON automotive forum.
Old Mar 6, 2023 | 10:37 PM
ford2go's Avatar
ford2go
I googled and found your post in a snowblower forum ( not much help there from what I could tell).
Anyway, the pdf manual there doesn't indicate anything about a hydrostat transmission. Maybe that's an option , but I didn't see it in there.
If it is the standard deal, there's a drive belt (shown in the manual and the whole bleeping thing has a drive disc a wheel drive wheel makes that turn -- it is moved in and out to change the speed. They do cause problems. I'd take another look. There are also some wheel lockouts shown in the manual that could cause issues.
Good Luck,
hj
Old Mar 7, 2023 | 12:37 AM
AntonyU21's Avatar
AntonyU21
4th Gear
Is the problem solved? I would also like to know how to solve this problem
Old Dec 4, 2023 | 05:58 PM
jackct's Avatar
jackct
1st Gear
Regards, Chet
mine has the disengagement on each wheel a little **** you pull out and turn
Old Dec 4, 2023 | 07:25 PM
oldcoupe42's Avatar
oldcoupe42
Thanks for all the replays men, turns out it was just an axle bolt that sheared off.
