Leaking Oil
Old Dec 4, 2023 | 04:52 PM
sailorman3's Avatar
sailorman3
Leaking Oil
I’ve got a 2017 with the 2.7 litre. 120,000 km. It was into the dealer while under warranty for a leaking base pan twice and the pan was replaced. It’s now leaking again, and it’s not a little leak. The plug has the drip coming off of it. Would it be as easy as just having to buy a new oil plug? Does the o ring have to be replaced ion them when the oil is changed? Or am I in for an expensive repair?
Old Dec 5, 2023 | 06:58 AM
Olds64's Avatar
Olds64
Did you replace the oil pan drain plug when you changed the oil? It's my understanding that it needs a new plug with every oil change (or at least a new o-ring).
Old Dec 5, 2023 | 07:19 AM
sailorman3's Avatar
sailorman3
No I did not. I don’t know that that had to be done.
Old Dec 5, 2023 | 11:31 AM
Olds64's Avatar
Olds64
Make sure you replace the oil drain plug, or at least the o-ring. The filter comes with a new o-ring for the housing as well.
I've considered getting one of these valves.
https://roninfactory.com/products/fo...-ronin-factory
Fr8dog69
Mar 21, 2021 09:14 PM
johnboy74
Aug 14, 2019 12:58 PM
apeman426
Oct 11, 2012 12:46 PM
paddler65
Oct 24, 2009 09:23 AM
damone
Feb 9, 2005 11:38 PM
