2023 Auto Hubs
Old Dec 4, 2023 | 03:13 PM
MDSuperDuty's Avatar
MDSuperDuty
2023 Auto Hubs
First a little background. My previous truck that I had for 12 years was a fully manual four-wheel-drive system. This new truck is the auto locking system. The situation I’m getting is the u-joints are clunking like my fully manual system did when the hubs were engaged at full wheel turn in 2WD. Am I missing something? Is there something you need to do to fully unlock the auto hubs?
Old Dec 4, 2023 | 03:19 PM
muisejt's Avatar
muisejt
the hubs can be manually locked, turn the hub counterclockwise for AUTO and clockwise for LOCK
Old Dec 4, 2023 | 03:39 PM
MDSuperDuty
I understand that. What I’m saying is I’m in 2WD and the u joints are bumping at full turn. I thought they disengaged when in 2WD? My manual system fully disengaged so turning was smooth. I also feel this new truck was lIke that at the start. But I’ve since used 4WD for snow and now I hear them.
Old Dec 4, 2023 | 03:44 PM
jcb804's Avatar
jcb804
This is happening with your hubs in the auto position and the transfercase selector in 2wd?
Old Dec 4, 2023 | 03:51 PM
muisejt's Avatar
muisejt
if the hubs are in the LOCK position you will get that so double check they are in AUTO
Old Dec 4, 2023 | 03:59 PM
MDSuperDuty
hubs are in AUTO and in 2WD
Old Dec 4, 2023 | 04:03 PM
rjacobs's Avatar
rjacobs
cycle everything.
You may have one thats bound up.
Put them both to lock, drive forward a bit, put them both back to auto(to get them to unlock), drive forward a bit.
Could also do this with the 4wd selector and leave them in auto(let the 4wd system lock and unlock them).
If one is still locked and bound, time to head to the dealer.
jcb804's Avatar
jcb804
climb under and rotate the each axle shaft a bit. One or both may just be stuck in a position thats maxed out when you go full lock while turning. If they dont move then they are still engaged.
Old Dec 4, 2023 | 04:17 PM
MDSuperDuty
I’ll try all of these.
The auto system is nice but that manual system was fool proof bullet proof the years I had it.
oh well.
Old Dec 4, 2023 | 05:08 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
oh well.
The hubs can be replaced with Warns if you so choose. I have a set sitting on my shelf for when mine give me trouble.
Old Dec 4, 2023 | 05:33 PM
MDSuperDuty
Well, Ford will be dealing with this if they continue doing this. Truck has 1000mi.
Old Dec 4, 2023 | 10:09 PM
DSLTRK60's Avatar
DSLTRK60
If they are indeed set to Auto, you need to spin the halfshafts by hand to verify that is the cause, and not something else. While you're under there, might as well spin the drive shaft to make sure it's not a transfer case shift issue. The "dog" clutch can sometimes be sticky if too much grease or corrosion is present in the hub assembly.
Old Dec 5, 2023 | 06:48 AM
HeavyAssault's Avatar
HeavyAssault
As a matter of ESOF practice (or manual hubs) when done with 4wd Ops, going back to 2wd I will drive in reverse for about 10yds. That way any gear lash that could be holding the hubs to the axle splines will relieve allow the hubs to unlock 100%.
Depending on the sound or feeling you are experiencing it could be a bad hub or poor vacuum. Potentially you might have a ESOF that's sticking, which prevents the hubs from retracting away from the axle splines correctly.
ESOF is pretty easy to diagnose if you think you have issues. Jack up the front axle with tires off the ground. Grab the front axle or either wheel to rotate. You will learn and hear what's going on.
Now ESOF isn't a bad thing with a little bit of learning. ESOF is not to be used when 100% stuck. You need to use ESOF before you get stuck.
There's a reason Warn has never made ESOF hubs to replace the Ford factory ones. Warn made them under contract that they cannot ever make a replacement ESOF version. Warn was split into two different companies (at this point) one that deals aftermarket, one that deals OEM only. These two companies are NOT tied together in any way from what I have been told.
So keep your Warn made ESOF hubs, or buy the "aftermarket" Warn hubs.
Old Dec 5, 2023 | 10:26 AM
willynilly's Avatar
willynilly
you dont even need to mess with the half shafts. just turn the driveshaft and both half shafts should turn if the hubs are unlocked
Old Dec 5, 2023 | 03:38 PM
4by4ord's Avatar
4by4ord
It doesn’t matter whether the hubs are in auto or locked. If the transfer case is shifting out of 4wd you shouldn’t be able to feel the front axle shafts rotating even with the steering turned all the way left or right.
The fact that you are experiencing the axle jumping indicates that both the transfer case and hubs are engaged. It might be something simple but you may as well let the dealer worry about it.
