2002 Excursion Limited problem HELP!
Old Dec 15, 2023 | 11:25 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
@babaleuska
Thank you for reporting back to close the loop on your issue.
If you don't mind, can you please tell us what the problem turned out to be?
Perhaps post the description of what your independent mechanic wrote on your work order, and identify any parts that were replaced?
This information will help us help the next Excursion owner like yourself who posts of a problem, or is being taken advantage of.
Old Dec 15, 2023 | 05:06 PM
babaleuska's Avatar
babaleuska
4wd High
The air filter was very dirty and replaced. A thorough cleaning of the throttle body was also done. The truck is running beautifully now. It is obvious that I will not be going back to the dealership. I had taken the Excursion there since I bought it 21 years ago. Very recently a new owner took over. A scan done by the independent mechanic showed no codes at all, though the dealership said a code P023 or P0231 came up.
happygameday
Jul 24, 2013 08:54 PM
capt_dan
Apr 21, 2009 04:45 PM
sage73
1997 - 2003 F150
Jul 6, 2002 10:10 AM
