Master Cylinder relocation
Old Dec 4, 2023 | 09:56 AM
BruinsRule's Avatar
BruinsRule
Trailering
Good morning all,
I am looking for a good thread that addresses the relocation of the brake master cylinder to the firewall versus frame mounted/underfloor. I have a 1951 F-1 and will go with the underfloor setup if necessary but would much prefer mounting the master cylinder to the firewall. I would imagine that there is some modifying to be done to the firewall so I am looking for suggestions/pictures etc.... to help with some direction and inspiration. Thank you in advance for your time and assistance.
Old Dec 4, 2023 | 12:30 PM
lshort's Avatar
lshort
I have never done the firewall mount but have done 2 of the frame mount with power booster, I like the look of the original pedals and the setup works good and you can still use the clutch pedal if you want, downside is it is a pain to check the brake fluid level
Old Dec 4, 2023 | 01:24 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Many of the frame mount kits have the option of using a remote reservoir akin to this example product:
https://www.lmctruck.com/1948-56-for...-reservoir-kit
Old Dec 4, 2023 | 01:55 PM
lshort's Avatar
lshort
I have looked at those but decided that I did not really need it and would just check the brake fluid when I had the truck on the lift, then on the first big trip after dark 200 miles from home I had some brake issues and was questing my decision to use a frame mounted master cylinder, no remote reservoir and dropped spindle m2 front! I am now thinking that a remote reservoir would be a good thing
Old Dec 4, 2023 | 01:58 PM
BruinsRule's Avatar
BruinsRule
Trailering
thank you all,
Definitelty some good info. I appreciate your replies.
Old Dec 4, 2023 | 02:55 PM
52 Merc's Avatar
52 Merc
The modification to the firewall isn't so much, not more than drilling a few holes and perhaps adding a doubling plate for good measure at the mount area, but the big thing is the bracing inside the cab, under the dash. The bracket needs to tie in the firewall with the dash structure for strength. Look under the dash of your modern car and you'll see what I mean. If you can, look under an older car, or even better an older truck, as it will be easier to see under there. Automakers use a large bracket/brace that bolts to the bottom of the dash and through the firewall, where the booster-m/c attaches, and the pedals hang from. Surprisingly, the distance between the firewall and dash hasn't changed that much over the years. I've contemplated doing the mod using a 70's or 80's Ford pickup pedal assembly. There are also aftermarket, universal kits to do the job, as well. Like anything of this nature, do your homework, research the options, and when you think you've got it figured out as for placement, comfort and function, go for it.
Old Dec 4, 2023 | 04:58 PM
M2HB's Avatar
M2HB
I am installing a Wilwood master cylinder that came from performance online. It is a 1955 version. I do not know if they make it for the F-1 truck.
As mentioned above, the setup has to brace the firewall to the dash. The instructions were not very good, but the quality was excellent.
There are a lot of folks who like to keep the firewall clean. For me, I like the firewall location because it is easily accessible and it is important to have the reservoir above the wheel cylinders. There is a reason most manufacturers have put the master cylinders there for decades. As long as the master cylinder looks good, I like it there. The Wilwood master cylinder looks awesome.
Old Dec 4, 2023 | 08:28 PM
jniolon's Avatar
jniolon
old and in the way
Here's an article I did years ago when I had a Volare ifs... I took the m/c-booster and pedal assembly from the same car and altered it to fit
Might not be an exact fit for a '48 but might give you some ideas on the xformation..
john
https://www.fordtruckzone.com/thread...-f-100.655090/
Old Dec 4, 2023 | 09:31 PM
F100supercrew's Avatar
F100supercrew
brake
CALL CPP--714 522-2000-- The BEST use them all the tome-- Talk to the Tech team get all your answers-- see what they offer for your year truck---
Have a good web site
Old Dec 5, 2023 | 05:20 AM
F100fun's Avatar
F100fun
I did CPP on mine, it's a good set up, they thought out the design well.
Jim
Old Dec 5, 2023 | 08:39 AM
BruinsRule's Avatar
BruinsRule
Trailering
Huge thanks to all who replied. That is exactly what I was looking for. Very much appreciated fellas. Happy holidays all......
DougieWebb
Feb 23, 2020 03:37 PM
Tim Hodgson
1978 - 1996 Big Bronco
Jan 29, 2019 10:18 PM
Maji
Sep 18, 2003 09:43 PM
jeffh
28
Nov 25, 2002 09:56 PM
