Radiator??
Old Dec 1, 2023 | 07:16 PM
BamaBiggDaddy's Avatar
BamaBiggDaddy
Radiator??
Have a 62 F100 uni switching to 302 with AOD what radiator anyone has been using. I have a brand-new radiator core support so would like a rad that will fit bolt holes. Someone said that up to a 78 would swap out> Going to go with electric fans if it works.Putting in new transdapt motor cross member and same tranny adapter only have to position get the 3degree on motor but looks like I have to order the 3 inch drop for the AOD.
Old Dec 2, 2023 | 08:59 PM
Ohmthis's Avatar
Ohmthis
I’ve read good things about Champion Radiators. That’s my plan, unless I read of a better option. Btw, my truck will be running a 5.0 and 5 speed, very similar.
Old Dec 10, 2023 | 04:32 PM
BamaBiggDaddy
I wouldn't mind a 5 speed but seems they mount so far back theres always a problam with seat
Old Dec 10, 2023 | 07:26 PM
Ohmthis's Avatar
Ohmthis
With the 302, check out the M5od transmission, it’s what I’m running (shameless plug, but check out my build 66 f100 Rustomod here). The T5 with an S10 tail shaft moves the shifter 5” or so forward. Check it out.
AFinley
Feb 13, 2021 11:25 AM
77ford250
Nov 11, 2020 08:33 PM
Rick_Fury
Feb 7, 2012 10:12 AM
HILLBILLY BOB
Feb 15, 2010 07:27 PM
Syzle
May 16, 2002 10:15 AM
