Break light s
Old Nov 30, 2023 | 08:00 PM
Dacs's Avatar
Dacs
2nd Gear
Break light s
I have a 1969 f100 the shop I took it to pulled wires under the dash. I was able to get most everything fixed but I haven't problem with my brake lights, when I stepped on the pedal my light come on with my dash lights. But when I have the headlights on I don't have brake lights. Any idea of what is going on would help
Old Dec 1, 2023 | 06:27 AM
Franklin2's Avatar
Franklin2
You have a bad ground to the rear lights. The rear lights should have 3 wires, taillight wire, brake/turn wire, and a ground wire. See where this ground wire goes. It should tie in with the reverse lights also, both sides, and then it might bolt to the rear frame. It must have continuity back to the negative of the battery. If you can't find where it grounds, you can go ahead and ground it to the rear frame, and then run a short wire from the frame up front to the battery negative.
Old Dec 1, 2023 | 06:07 PM
Dacs's Avatar
Dacs
2nd Gear
Thanks I'll check that out after the snow leaves
egchewy
19
Jun 16, 2022 07:32 AM
mrstephs
Apr 10, 2016 11:10 AM
ldouble619
19
Mar 16, 2014 09:47 AM
colad
1978 - 1996 Big Bronco
Aug 24, 2007 02:37 PM
62Cole
Feb 3, 2006 03:21 PM
