I have a 1985 f150 302 manual, it has a carb and the motor is not stock. It originally had a i6 but then got swapped to a 302, when the guy swapped the motor he uses the duraspaek ii ignition systems, everything is hooked up as should be and everything works. The 302 has an auto lite 2150 on it, the motor was bored to a 306 and had a slightly bigger cam in it, nothing serious. It has 3.27 gears in the rear with a 4 speed with od manual, I don’t drive the truck that hard, and I still get around 9 mpg. Would anyone know what could be the cause or could give some tips to help?
it has a brand new gas tank and sending unit in it, I have also completely replace the ignition system with a new distributor, factory motocraft ignition control module, and new ignition coil, I never take the rpm higher than 4, normally stay around 2-2.5k.
Do you smell gas, as if I you have a fuel leak or as if you are running rich. Is the choke operating properly? Is the engine winding out in the power bands when shifting up building speed, running strong? Or is performance weak? 9 mpg is too low for a properly tuned engine.
I do not smell gas when it’s running and there is no leaks that I can see of, it does seem to lack a lot of power but that could because it’s a later model 302, I’m unsure on the tuning of the cam to crank but it is timed properly on the dizzy , the carb works as it should and the truck starts very easily
Last tune up was? Spark plugs look clean and hot burning? Wires?
My experience with the 302 is limited but my neighbor had a carbed 302. It ran like a Swiss watch. A good match for a 150. He said he was getting 15 mpg. He wasn't racing it around. Proper tune up is a first step. Your carb may be adjusted rich. How's the exhaust system?
It could be your rear end gearing.
From research I have been able to do. It appears that when ford put 302's and a overdrive transmission they installed either a 3.55 or a 4.10 rear end.
It seems that the 302 likes a little higher rpm than the 300. Makes sense as far as the torque curves goes.
I changes from a 3 speed to a m5od, I got poor fuel milage much like yours.
When I ran across the differences in rear end gearing. I installed a 3.55 and now I run a average of about 15mpg
Although my motor is a bit more modified than yours i think.
I was thinking about putting 3.55s in the rear, that’s what it had in it stock. I’ve been thinking it would help the mpg
it has stock exhaust manifolds, everything else behind it is new, it’s small pipe, like 2 inch I think
Do you have a tach in the truck and if so what is the RPM @ MPH in what gear?
Also a AFR (air fuel ratio) gauge helps so you know just how it is burning the fuel.
To see if a higher RPM from a gear change will work you can try running a tank of fuel and not use over drive.
You may want to do a little math to see what the final ratios are in the transmission with the different rear gear ratios to see if the 3.55 will put the 302 in the sweet spot and the need to go with say 3.73 gear?
I have a 300 six manual granny 4sp with an over drive unit and a 2.75 rear gear.
I can tell you at 45 MPH and in over drive it runs richer then in 4th gear based on the AFR gauge.
I can also tell you I got the same MPG, avg 15, with and with out over drive.
The only thing it did is lower the RPM so I have less engine wear and if pulling a heavy load can split all the gears.
Dave ----
Oh the other thing how sure are you the miles on the odom are right?
Running a different size tire then factory will throw the miles off.
Also how many tanks of fuel did you run to get the 9 MPG?
I know mine is on the money based on a GPS I have used to make sure it was good.
Dave ----
I do not see any problem with anything you described with the truck so far. So that leaves timing.
1st thing to check is the vacuum advance. Pull the rubber hose off the distributor, and see if you have vacuum on it at idle. Also if you have vacuum on it at idle, does the engine slow down when you pull the line off? If it does, that means the vacuum advance unit is good. If you have vacuum on the vacuum line all the time, and the engine speed doesn't change when you pull it on and off, something is wrong with the vacuum advance. It's a big contributor to fuel mileage.
If you do not have vacuum on the distributor at idle, rev the engine while checking the line with your thumb. If you suddenly have vacuum when you rev the engine, that means the vacuum is on a ported source, which I personally like. But to check the vacuum advance in this situation, find a capped off vacuum port that has suction on it at idle. Move the distributor line to there while the engine is idling, the engine should speed up. If it does, that means the vacuum advance unit is good. If not, it has a problem.
Enlighten me, what's the difference between running the ported vs constant vacuum to the distributor?
When I bought my Holley, the instructions said "THIS PORT IS FOR VACUUM ADVANCE" and it is constant vacuum.
Are you sure it has vacuum at idle and if so what is the idle speed?
If it is a ported port and the idle speed is to high then it can have vacuum at idle.
As for what type of vacuum to run it is up to the person what they want to run.
Some say running manifold vacuum will advance the timing at idle and raise the idle speed,
You then adjust the idle speed back down but now when you shut the motor off the timing goes back even more for easier start up when hot.
any help would be greatly appreciated
Reading the comments the only thing I can add is check for brake drag front calibers sticking brake grease may help sticking and rear brakes adjusted to tite and front alignment.
Interesting, this is the first I've stumbled across ported vs constant vacuum and now I need to go give myself 3 days of headaches trying it out. I do need to find a vacuum that isn't constant first though.
