Tail light problems
Old Nov 29, 2023 | 06:05 PM
Carly44882's Avatar
Carly44882
2nd Gear
Tail light problems
My tail lights, turn signals and reverse lights don’t work but the hazards do. When I use the turn signals the hazards turn on. This all happened after pulling a trailer a couple thousand miles. Has anyone had this problem?
97 f350 xl 4x4
Old Nov 30, 2023 | 03:21 PM
Franklin2's Avatar
Franklin2
I am guessing your trailer plug is tied into the truck lights, not the trailer tow harness. If that is true, there is most likely a fuse blown. You have two fuse boxes, one under the hood and one under the dash I believe for your year.
Old Dec 10, 2023 | 02:39 PM
Carly44882's Avatar
Carly44882
2nd Gear
Problem solved I found that the ground wire for my tail lights were worn in half. Spliced them back together and no problem since. Thank you for the advice.
86XL5-OH
22
Mar 21, 2020 03:42 PM
zoomeroo
Jul 18, 2014 05:02 PM
frigerator
Feb 28, 2009 09:26 PM
MatthewC
1978 - 1996 Big Bronco
Oct 8, 2004 10:50 AM
