Distributor is stuck
Old Nov 29, 2023 | 12:45 PM
56panelford's Avatar
56panelford
Distributor is stuck on the 5.8 engine I'm using on the 56 Mercury I'm tinkering on. I've been soaking it with Seafoam Creep last couple days and no luck so far..anyone else run into this problem and been successful..?
Old Nov 29, 2023 | 01:07 PM
DieselDog409's Avatar
DieselDog409
carefully use a oxy acetylene torch and a pipe wrench to break it loose, if that fails break it off and cut it out of the block carefully.
Old Nov 29, 2023 | 02:30 PM
Old F1's Avatar
Old F1
Wouldn't cooling the distributor body (contracting) be better than heating (expanding) . I have never used it but wouldn't dry ice work ?
Old Nov 29, 2023 | 02:51 PM
52 Merc's Avatar
52 Merc
Yeah, I'm picturing that aluminum distributor body melting into a big puddle with the oxy/acy torch. Some people's kids.
Soaking with some type of penetrating fluid and gentle pressure from a big pipe wrench has been the time honored method that I know of. Might try a 50/50 mix of acetone and atf. That seems to creep into most anything.
Old Nov 29, 2023 | 03:30 PM
56panelford
I was able to get it free. I used my MAP torch and heated the block around the base of the distributor and not directed at all on the aluminum then quenched it with that Seafoam Creep penetrating oil. Used a 12 crescent wrench and tapped back and forward with a hammer. Took three tries before it started to move. Now I have two intake manifold bolts I have to drill and tap out , one on the front of each head. The two at the back were rusted pretty good too but the not as lucky on the two front ones..there is lots of slack on the timing chain and appears to have jumped one or two teeth on the sprocket, it's amazing the thing ran as well as it did before I pulled it out of the donor truck..
rswhitmore
Mar 16, 2022 09:16 AM
chris989
Sep 19, 2021 07:52 PM
go2toa
Aug 15, 2006 11:07 AM
Delzell
21
May 28, 2006 06:38 AM
kwieringo
Jan 17, 2002 12:37 AM
