351w swap help
Old Mar 19, 2024 | 03:45 AM
joe21972's Avatar
joe21972
6th Gear
You need to use the 351W firing order. The injectors are bank fired so that won’t affect anything. You are reusing the transmission that is behind the 302, correct? You will need a different flex plate.
thanks. Is the 351 flex plate different on the cable controlled vs the electronically control trans? I do have a 351 flex plate if they are the same for both transmissions. Yes I’m reusing the transmission from the 302. I do very little with efi and computers etc. so on that topic the injectors are bank fired. Ok what exactly does that mean?
The firing order on the 302 is 1-5-4-2-6-3-7-8 and the 351 is 1-3-7-2-6-5-4-8. So if I run the 351 firing order it should be fine?
Thanks, Joel
Old Mar 19, 2024 | 08:35 AM
BlackBeautyFlareside's Avatar
Bank fire means that the driver side fires all four injectors at the same time then the passenger injectors all at the same time. The 1994 5.0 and later had sefi which is sequential firing so only the cylinder on its intake stroke would get a squirt from the injector.
Old Mar 19, 2024 | 09:20 AM
rla2005's Avatar
rla2005
Correction...
On V8s the injector firing is 1,4,5,8 then 2,3,6,7
Ford Speed Density EFI is batch fired, not bank.
Old Mar 19, 2024 | 02:39 PM
joe21972's Avatar
joe21972
6th Gear
Originally Posted by rla2005
Correction...
thanks. So if I use the 302 wiring but run the 351 firing order it should work correct?
Old Mar 19, 2024 | 02:55 PM
rla2005's Avatar
rla2005
Injector firing has no influence on the spark firing order on Speed Density Ford EFI vehicles. Ford uses the same injector firing for the 5L, 5L-HO, 5.8L and 7.5L engines.
Old Mar 19, 2024 | 03:25 PM
Yes it should work for you. The only difference I can think of is that the 5.0 engine harness will have a knock sensor at the back of the engine. The 5.8 does not have a knock sensor. At least there isn't one on my 94 F250 or my 94 Bronco, both 5.8 Speed Density EFI. I would guess that you could just leave that plug hanging and be alright. Maybe I missed something, why not run the 5.8 engine harness on the 5.8. In the 1989 models, is there a plug on the drivers side fender to plug the engine harness into with a 10mm bolt? The 5.8 harness should plug right in there.
Old Mar 19, 2024 | 03:44 PM
Conanski's Avatar
Conanski
Correct... just leave the connector hanging. The knock sensor isn't significant enough in the programming on this vintage truck to do anything you would notice from the drivers seat, and it's absence will only set a minor code at most, no check enging light.
Maybe I missed something, why not run the 5.8 engine harness on the 5.8. .
Because of wiring harness differences. In this case the motor came from a van so it will be pinned and loomed differently than the pickup version. Elecrtrically both motors are the same so either harness could work but the 5.0 pickup harness is guaranteed to make the project plug and play while the van harness will need to be modified.
Old Mar 19, 2024 | 03:49 PM
Thank you for the clarification, Conan. I'm not familiar with the Econolines.
Old Mar 20, 2024 | 01:18 AM
joe21972's Avatar
joe21972
6th Gear
Thank you all for the reply’s
Thanks everyone. Feeling more confident about this swap now. Van will be much better with the 351. This is my first go swapping with fuel injection and everything that goes along with it. So much to learn. Or maybe I’ll stick with my older stuff. Pre 79 and I have an idea what I’m doing. Thanks again
Old Mar 20, 2024 | 10:41 AM
Conanski's Avatar
Conanski
Hey Joe what trans is in your truck now? If it has an AOD you cannot use the flexplate that is currently attached to the 5.8 it will destroy the pump the first time the engine is started. This combo requires a unique flexplate that was only ever factory in an mid '80's crown vic. If the truck has a C6 then the flexplate s good to use.
Old Mar 20, 2024 | 10:49 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I asked that question but did not get an definitive answer.
Originally Posted by joe21972
… My van has a cable controlled transmission and the donor 351 is also from an 89 van but has an electric controlled transmission. Can I pull the ecm from donor van and will things work correctly?
thanks. Is the 351 flex plate different on the cable controlled vs the electronically control trans? I do have a 351 flex plate if they are the same for both transmissions. Yes I’m reusing the transmission from the 302….
joe21972, Would you tell us the transmission code on the driver’s side B pillar sticker?
Old Mar 21, 2024 | 12:16 PM
joe21972's Avatar
joe21972
6th Gear
sorry for the delay. Just got back home to get info.
Transmission code is T. Which I believe is the AOD
I'm wanting to upgrade the van. The 302 has 400k on it and dropped a cylinder. Would not pull hills without constant shift down before loosing cylinder.
If I have to find rare parts I’ll probably just rebuild the 302.
Old Mar 22, 2024 | 11:13 AM
  #28
Conanski's Avatar
Conanski
Yeah that is the AOD, the correct flexplate for the 5.8/AOD combo is not rare or hard to find.
Old Mar 22, 2024 | 12:30 PM
  #29
joe21972's Avatar
joe21972
6th Gear
ok thanks. Appreciate it
88XLTLariat
Feb 14, 2017 08:32 PM
86ford94
Aug 20, 2011 06:45 AM
Nyls
Jun 10, 2009 08:28 PM
Amenjephra
17
Nov 14, 2002 11:47 PM
desperado_18_2000
Aug 9, 2001 09:27 PM
