Rear Cab Vents
I see all the threads which detail the rear cab vents leaking, and the 3rd brake light and rear body panel seams. I intend to check it all, but carpet is wet.
My current plan is to take a piece of sheet metal, panel bond it across the existing rear cab vent holes. Inside this piece retrofit a 3C3Z-54280B62-BA. This is dished such that if any water makes it inside, it gets forced back outside.
I also intend to drill a couple of holes in ]the channel which the sill plates cover, to force water out. Although I didn't find water here and my carpet was wet.
Panel bond is rust resistant and used as seam sealer in lap flanges, and has crazy tensile strength. I will post back if my idea works.
His username escapes me at the moment. When I think of it again, I'll update this post.
UPDATE: Curated thread where FTE member av8or1 welded in later style cab sheet metal to fit newer style cab vents
Last edited by Y2KW57; Nov 26, 2023 at 12:53 PM. Reason: Updated post to inlcude link and member name referenced
I ended up modifying the existing vents and using a butyl based sealant tape from the RV industry to seal them back into the cab.
https://www.ford-trucks.com/forums/1...l#post20066487
My journey to fix. Which btw is still holding up nicely which I should hope so at just a little over 2 years.
Normally I'd consider the same and put vents elsewhere, but I like having tight weatherstrip seals, and easy shutting doors.
Also want to see if it can be done.
I've also seen in other threads in general on these relief vents that AC flow is hampered, and the last/unknown purpose is such that your ears don't get hammered with pressure with an airbag deployment.
Not looking forward to pulling down the headliner to get to the mounting nuts.
As far as the cab vents go the design flaw was the 1/8” lip at the bottom leading edge and the lack of a side dam on the uppers like there is on the lowers.
If I had the capability to plastic weld I would have gone that route to build them up.
The way Ford sealed them to the cab left a lot to be desired as well.
I chose a butyl tape over a foam seal or caulking there because I wanted something that was non porous ( foam ) and remain soft and flexible not like a caulking that would cure and would potentially become a service item.
I finally found the member, but his build thread meanders all over the place for pages and pages of content unrelated to cab vents.
Earlier today, I copied the cab vent relevant posts from his thread, and created a new thread, but then somehow lost that thread in cyberspace somewhere.
I'm looking it for it now. I'll try and have it together by end of day today.
Last edited by Y2KW57; Nov 26, 2023 at 12:54 PM. Reason: Updated post to include link to curated thread of copied posts previously lost in cyberspace
It appears my idea will not work without modification due to the new vents being taller than the old ones. So hmm back to thinking on it.
I've looked at Chevy, and Dodge vents. Dodge vents are square and large, chevy vents are tall and skinny, with flaps going the wrong way to turn it on its side.
Big thanks to F350 towing for his thread too, on how to modify the factory vents.
I've been looking at this set of 04+ vents (larger style with built in dam at bottom). I've not exposed my factory vents yet to compare on measurements.
So far my idea is to use the same idea to place a piece of sheetmetal over the factory hole with panel bond. As shown in the above picture, the new style is taller so I may need to carbide burr/grind/cut down the factory lower factory flange a bit to even fit the vents through. I know from experience panel bond is kick ***, and totally rust resistant. I'm semi concerned though if I clearance the bottom and stick the vents through, what are the tangs gonna grab onto... It would suck to get the vents fitted then learn that the tang spacing is too skinny to clip onto double thickness sheet metal.
I've been considering ways/locations on the vent in which I can cut down the new vents 1/8" or so in height and then fuse them back together as well.
It makes me curious though, the water comes into the vents either the top, sides, or through the vent itself. Runs across the floor and then down the sill channels (not the case on mine). Some have drilled a hole in the sill channels to kick out the water. It makes me curious if a guy drilled a couple holes below the vents in the floor, if water came in would it not exit right out through the cab, instead of running across the floor? A proper rubber grommet with a hole could likely even be fitted here.
In the meantime, water would still be absorbed by the jute padding, which is even under factory vinyl floors in carpet delete trucks.
The misty windows and the musty smell would still be present until the moisture saturation evaporated.
Water won't limit itself to flowing straight down to a drain on a flat plane.
And the plane is not flat. Even the seam sealer slathered along the inside corner between floor and back cab wall presents a surface texture with its own valleys... that can become creeks directing water away from your grommeted hole.
I'm not trying to "rain" on your ideas... in fact, I admire your thinking solutions through before starting.
Yet, you need the benefit of actually seeing what you are working with in order to give your creativity the best physical data to noodle on.
If you don't have a family or crew that needs seat belted positions in the back seat on a daily basis, I recommend that you go ahead and pull the seat and interior C pillar trim, and remove the back trim panel, in order to see and feel what you are working with, which will inspire your imagination with the physical facts needed for an effective solution.
Sorry if this is a dumb comment as I’ve never dealt with these personally so am only basing this off of y’all’s posts.
With respect to the drain idea, what about if I made a dam on the floor with strong cauling/butyl rope the width of the vents connecting to the back cab. IE water runs in and down the back cab it then gets stopped in the dam and out the floor hole in the middle of it?
