1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 f250 won't turn over
Old 11-17-2023, 09:47 AM
Glenwood's Avatar
Glenwood
Glenwood is offline
3rd Gear
I have a 2011 f250 6.2 had to change the bushing on the transmission side of the shift cable ots now shifting through the gears fine but when I go to start everything lights up but won't turn over also just bought a new battery any help would be greatly appreciated!!
Old 11-17-2023, 07:35 PM
WWR's Avatar
WWR
WWR is offline
Try N
I'd suspect the neutral safety switch
Old 11-17-2023, 07:37 PM
Glenwood's Avatar
Glenwood
Glenwood is offline
3rd Gear
Thanks
Originally Posted by WWR
Try N
Is there a way to test or bypass it also do you know the location
Old 11-17-2023, 07:45 PM
WWR's Avatar
WWR
WWR is offline
Of course try N
Some position will allow continuity if it's just misadjusted.
You can try D or R but be ready to shut it off immediately and be standing on the brake
You say you replaced a shifter bushing and now it doesn't start, so I'm just shooting for the obvious first
Old 11-17-2023, 07:55 PM
Glenwood's Avatar
Glenwood
Glenwood is offline
3rd Gear
Thanks
Of course try N
Yes will not turn over in any gear or neutral and yes just changed the bushing that connects the cable to the transmission
Paul and Carol
10-11-2021 10:53 AM
johndou
06-29-2021 10:21 PM
johndou
Electrical Systems/Wiring
06-29-2021 03:03 PM
devo2810
12-03-2017 05:50 PM
kitteekate
26
08-21-2007 12:25 AM
Quick Reply: 2011 f250 won't turn over
