How to Install Hubcaps?
Old Nov 17, 2023 | 01:15 AM
turbosocal's Avatar
turbosocal
4wd Low
How to install hubcaps I bought on these wheels? These are 15" wheels. Hubcaps are poverty/dog dish style 10.5"
Old Nov 17, 2023 | 06:26 AM
Sortofa65's Avatar
Sortofa65
Those appear to be the newer hubcaps probably for outie rims. I believe they are not going to work with what you have.
Old Nov 17, 2023 | 06:36 AM
AZSCAWPION's Avatar
AZSCAWPION
Sortofa65 is correct. The wheels you have are what are called "innies". The nubs that hold the caps on are on the inside of the lip. They were common through '66 and the original bottle cap style hubcaps that fit are reproduced. The cap you have would fit the later years "outtie" wheels
Old Nov 17, 2023 | 11:20 PM
turbosocal's Avatar
turbosocal
4wd Low
OK so I now understand I have 15 x 7 "INNIE" wheels on the front of my truck and 15 x 8 "OUTIE" wheels on the rear.
Looks like I will need new OUTIE wheels for the front.
Where to buy the 15 x 7 OUTIE wheels?? For my 1966 is that a 5 x 5.5 bolt pattern?
Old Nov 18, 2023 | 01:05 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Have you seen this ad, from the FTE Marketplace? It’s what your truck should look like, to me, and is a whole bunch better than the other caps you posted.
https://www.ford-trucks.com/forums/market/1727257
Not so sure that the stock innie F100 wheels are actually 7” wide, since my F250 came stock with 6” x 16”. Someone here will be along shortly that does know. I saw your other post looking for two more outie wheels so you can use those other caps. I wouldn’t do it, I’d buy that complete set of wheels, tires, caps from member SSgt82-02, if I could, they’re a great deal.
But, if you must, there is a set of tires, wheels, and those same caps for sale on FB Marketplace in Los Angeles, your neck of the woods, I believe. I can never seem to get links to FB ads to post here on FTE, but you’re a bright lad, you can look them up, I bet! The sellers name is Peter Acosta.
Split rims
2021+ Bronco Sport
Nov 24, 2022 06:56 AM
JTB321
Jan 13, 2022 10:03 PM
speakerfritz
6.7L Power Stroke Diesel
44
Aug 12, 2021 06:28 AM
Gicknordon
Apr 20, 2021 05:07 PM
SunDown
Nov 5, 2009 09:31 PM
