For what it's worth: I left an LED on inside my camper shell which almost entirely drained both batteries (I have a 7.3L 2022, dual alternator, dual battery). Voltage on both batteries was around 1 or 2V. I connected a trickle charger on the passenger side battery only. Within about 24 hrs, BOTH battery voltages were normal. So they are in parallel and there is nothing shutting off the connection between them.
So I learned the other day that I can only jumpstart another battery using my passenger side battery.
when I tried with the driver side battery I wasn’t getting anything. Switched to passenger side and it worked.
I had a dead battery on a telehandler and thought that was interesting because I always thought they were both in parallel and thus would be able to jumpstart all the same.
I thought I read they are isolated from each other, at least when the ignition is off. .... Not sure if the diesels are wired differently.
In all cases the two batteries are hardwired in parallel. There is some wishful thinking that the two batteries perform as you stated, so that when parked the use of accessories with engine off doesn't kill both batteries, and you can then start the truck reliably. But that is not the case. They are permanently connected.
Originally Posted by Need2Speed
The references to "charging" in my 2020 owner's manual are for wireless gadget charging. Did find this, though...
Does this suggest that, when charging a dual battery system, one should not connect a lead to pos of one batt and the neg of the other? .
No it does not. It concerns the BMS system being able to monitor the load on the battery, If you connect a heavy load, like a winch or compressor, directly to the battery posts, then you have bypassed the BMS sensor. Charging or jump starting directly to the battery is not a problem.
You could charge as you stated, positive on one, negative on the other, but what would be the benefit of that?
I finally decided to experiment and put the charger on the passenger side (2022 F350 Diesel) battery and charged it until I got a green light. Next, I hooked the charger up to the driver's side battery. It was hours before I got a green light. I conclude that charging the passenger side battery does not charge the drivers side. I have yet to try this the other way around or chack with a volt meter.
Put the charger/maintainer on the passenger battery and it read lower than I expected for ac3 month old truck, 60% or so. Should have checked the driver side but didn’t. Left it on maybe a week. Checked the driver battery and it was 95%. Left in on several days. Rechecked the passenger side, it was 95%.
What's happening here is that there is more resistance to the driver side battery. Because of that, the passenger side battery where you connected the charger has less resistance and gets charged first. Once the passenger battery is charged enough where the resistance equalizes then the driver side battery will get the current. It takes a while, especially if you have batteries that are at a low state of charge.
The ideal connection is to put the positive lead of the charger on the positive of the passenger battery and the negative lead of the charger on the negative of the driver battery (or vice-versa). This way the resistance is the same for both batteries and they both charge, assuming that both batteries are in good shape and there isn't something wrong internally.
In theory, the overall time to charge both batteries to 100% is the same with both connection methods. In practice, there's likely some difference. If you have limited time to charge and want both batteries at the same state of charge then use the second connection method. For my truck, which has AGM batteries (aftermarket), I'm using the simple connection method. My truck sits for weeks in the garage during the winter.
