'53 F100 - CPP Clutch Pivot Bracket
Old Nov 14, 2023 | 10:52 AM
EarlsFat's Avatar
EarlsFat
Has anyone installed the clutch pivot bracket from CPP and not haven't be extremely sloppy? We've gotten ours just about done, and it's so bad that there's no possible way that this is correct.
Any recommendations on tightenIng that up?
We were just gonna stack some washers on that to take up the slack.
Old Nov 14, 2023 | 01:34 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
The larger hole in the equalizer bar does just float over the bushing on the pedal shaft. Then there is a spring that fits between the bushing and the "collar" (not represented very well in the drawing. I would call it an arm) that swings the equalizer bar.
ETA: Spring Location
ETA2: Here is a picture showing the bushing and spring reversed. I've always thought it should be like this but put mine together the way it came apart. Either way, it gives a better look at the spring.
Last edited by EffieTrucker; Nov 14, 2023 at 02:15 PM. Reason: Added Spring Location Picture
Old Nov 14, 2023 | 03:01 PM
EarlsFat's Avatar
EarlsFat
Ok, so I'm missing the spring.
The design seems to lend itself to excessive wear.
Old Nov 14, 2023 | 03:19 PM
EarlsFat's Avatar
EarlsFat
Anyone have a modern equivalent of that spring? LMC, Dennis Carpenter, CMW, mid-Fifty... none of them seem to have it.
cullynhaas
Sep 2, 2023 11:26 PM
Mushroomman63
Mar 9, 2022 10:22 AM
janco
Bronco II
Jan 11, 2022 03:05 PM
Lawrence Petty
May 25, 2020 02:55 PM
lvin4jc
22
Nov 20, 2019 08:49 AM
